stephen thomas
- Jun 3, 2001
I'm building an oven which includes a squirrel cage blower fan.
The fan is well down in the hot section and (is intended) to distribute hot air from the duct-enclosed elements out into the box. Operating temp is 325 - 350 F. Max temp is 500F.
This thing won't be used often, but the bearings need to be "reliable" in the sense of not seizing up. They can be pretty loose tolerance, there's nothing else critical about locating the blower shaft, max 1200 rpm. Only one bearing will be down just above the hot chamber separated by a 26 ga sheet. The other will be above the insulation, out in ambient air.
I have browsed the catalogs for high temp bearings, they are overkill.
Cheap is the modus for this part.
Other than "try-it-and-see" does anyone have experience using clapped out loose (sloppy) ball bearings for a hot app like that? Needs to work well a couple hours at a time, for maybe 50 hrs total. The rest is bonus.
Any preference for (non-graphite, non-exotic) plain sleeve bearings?
Thanks!
smt
Thanks!
smt
