Disaster Area
Cast Iron
- May 6, 2005
Is a (SKF) 6205 (double shielded) an acceptable replacement for a New Departure 88505?
Is a 6205 a good replacement (or supercedes) a 88505?
It appears that they are almost identical, the difference being the width of the inner bore of the bearing (88505 is .591" = 15.0114 mm, vs 6205 which is 15 mm).
The application is 6 bearings on a shaft running at about 2,000 rpm (maybe less) in a lathe (a component part of a "twin disc clutch"). It was installed in 1940 (more or less). This is the 88505 (beneath the sleeve):
http://s64.photobucket.com/albums/h186/Disasterarea_photos/Hendey%209%20x%2018%20Lathe/Twin%20disk%20clutch%20Co/?action=view¤t=IMG_0003.jpg
Is this (88505) an archaic bearing?
tia
tia
