Beginner, need to make six S/S pieces .090" dia, +.001 X 2" +/- .005"
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jan 2006
    Florida
    121
    6
    Default Beginner, need to make six S/S pieces .090" dia, +.001 X 2" +/- .005"
    Trying to turn down a 3/16 X 3" round piece of 303, S/S to a finished .090" X 2" on my 10EE Monarch. Collet on one end and a 1/2, MT2, small nose live center at the tailstock end. Also, tried an MT2, 1/2 dead center. Both did not allow me anywhere near enough clearance. Need six pieces. Two questions; (1) What MT2 piece of equipment might be available or that I could make for the tailstock that would give me the support and clearance necessary. (2) What might be an appropriate work around to accomplish the finished pieces. Also do not have a .090" collet. Please be specific with your suggestions. Thanks!
    Sep 2010
    Oklahoma City, OK
    4,472
    773
    1849
    Turn it in steps to minimize deflection then blend with sand paper.
  3. Likes JohnEvans liked this post
    Jan 2011
    Fairfield, PA
    374
    180
    175
    Does it have to be stainless? You could buy pins like these and cut to length:
    McMaster-Carr
    Part # 98378A703
    Mar 2005
    Palmer, Alaska
    3,603
    747
    Look up lathe box tool.
    It has a bushing/guides/or rollers, that support work very close to where material is removed. Support moves with cutter.
    Deflection is no longer an issue.
    I would think a swiss style lathe, or a grinder would be a better way to get the job done...
  6. Likes digger doug liked this post
  7. #5
    Sep 2013
    Michigan
    258
    90
    154
    Be happy to make as many as you want for time and materials on my Heavy 10, size guaranteed...
  8. Likes Bobw liked this post
  9. #6
    Feb 2006
    Indiana
    12,940
    686
    3904
    Seems like it would be easier to make it from 3/32" stock. In my shop, I would use a Levin lathe that I can lift with one hand for little pieces like that. I have seen a 10EE and know it is nice, but too heavy for me to move, so I never bought one.
    Anyway, a roller box tool, once adjusted, could do the job with ease. I use 2 and 3 Morse taper end mill holders in my conventional tailstocks to hold 5/8, 3/4 and 1" straight shank turret tooling for simple one-tool jobs.
    Larry
  10. Likes Ron Hofer liked this post
  11. #7
    Feb 2005
    9,048
    13911
    10719
    Are you trying to make spaghetti???
    Find a company that grinds stock for swiss machines, buy a length and be done with it.
    I've been forced to do stupid shit like that, and there are some things that are just
    better off being sent out to the right people that have the right equipment to do the
    job..
    Box tool would be worth a shot..
    And a thought.. Tailstock.. Instead of pushing or letting it run dead.. Anybody ever
    tried grabbing the material in the tail stock with a collet or something and pulling back..
    Put the material in tension??? Just a thought.
  12. #8
    Sep 2010
    Oklahoma City, OK
    4,472
    773
    1849
    Quote Originally Posted by Bobw View Post
    It is impossible to pull on something hard enough axially to prevent radial deflection in the middle, the vectors won't allow it.
  13. #9
    Feb 2005
    9,048
    13911
    10719
    Quote Originally Posted by Cole2534 View Post
    You are never going to eliminate deflection.. But I can push a lot harder on a rope that is in tension than I can
    on one that is in compression. The more tension its under, the harder I can push.
    I know metal isn't rope, but 2" of .090" 303 isn't too far off.
    As an aside, at what diameter does it go from "bar stock" to "wire"??
  14. #10
    Sep 2010
    Oklahoma City, OK
    4,472
    773
    1849
    Lol, I wonder about the same thing with sheet and plate.
    You're right, as nothing is perfectly rigid. Where this gets all weird is that since the shaft is presumably straight the tensioning would only produce vectors in the item's axis until it was deflected into a catenary of sorts. For the tension to provide any straightening the shaft would have to deflect well beyond his +.001" spec.
  15. #11
    May 2010
    Cambridge, MA
    1,648
    71
    942
    Default Pin-Turning Jig
    This type of problem can be solved with a pin-turning jig. This sort of thing is not sold anymore that I know of, at least for any reasonable amount of money, but you can make one as follows:
    A pin turning jig can be used to turn pins either on a lathe, mill or drill press. On a lathe the arm of the pin turning jig should be sized to mount on whatever rest you have. On a mill or drill press, the arm of the pin turning jig is clamped to the table.
    The parts needed are the:
    - the frame of the jig cut from 0.5" plate
    - 0.5" bushing
    - 3/16" cutter
    - a small toe clamp
    - (2) 1/8" x 1/2" steel pins
    - 3/16"-32 7/8" cap screw
    - (2) 6-32 1/4" set screws
    [Frame] Cut out the frame. A plasma cutter could be used or even a hacksaw. Grind and finish the edges to be straight and smooth. Drill and ream the hole for the bushing.
    [Bushing] Ideally, the bushing should be turned from D2 tool steel and hardened. A bevel can be added to the back of the bushing to make it easier to feed the work into it. A hacksaw/file or a mill can be used to cut the notches out from the bushing to form its tongue. You could alternatively use a milling attachment on a lathe.
    Insert the bushing, tongue up, into the frame and scribe a line across it and the frame. This can be used later to make adjustments.
    The set screws can be used to rotate the bushing and adjust the depth of cut.
  16. Likes swatkins, lalatheman liked this post
  17. #12
    Dec 2009
    657
    498
    446
    I have a Geometric head that I use for that sort of thing. I have one set of inserts with the threads ground off that I can run up on to a small diameter pin to cut a smaller size and no deflection involved.
  18. Likes digger doug, camscan, lalatheman liked this post
  19. #13
    May 2012
    Indiana
    990
    181
    356
    Not enough clearance? Between what? Turn between centers using a long cutting lathe tool.
  20. #14
    Apr 2005
    Beaverdam, Virginia
    7,454
    704
    3518
    So I take it you need a 3" long part with two diameters on it? 2" of .090 and the rest 3/16" stock diameter? What is it's use, does it have to be .303? Can you just press an .090 pin into a 3/16 slug?
  21. #15
    Jul 2008
    Ontario, Canada
    257
    6
    85
    Information is lacking, but I'm going on the assumption the finished part is a cylinder 0.090" diameter (+0.001/-0.000) x 2.000" long(+/- 0.005). Although I have a feeling there are probably other ways to do whatever the OP is trying to do without making such a crazy little part on a machine not designed to make it, we'll just ignore that for now.
    I figure you can probably find some kind of SS rod that's either exact or very close. Welding rod comes to mind, though I can't recall offhand what's common for diameters. Purchasing some kind of small diameter stock is probably the most efficient way to go as long as you can convert it into what you need. Google is your friend, my friend.
    A quick search of McMaster-Carr resulted in 3/32" (0.094") 316 SS shaft that comes in various lengths that you could cut and grind to length. I figure I could probably carefully hand-polish it down a
    thou or three in a pin vice on a lathe to the required diameter, so I'm sure you can too.
    McMaster-Carr
    The cost is less than the value of the time you've already spent typing your question, so there isn't much point trying to make it on your lathe if it works.
  22. #16
    Jan 2014
    Connecticut
    158
    73
    36
    I think I would inquire at a shop that does centerless grinding.
    Bill
  23. #17
    Mar 2009
    Washington
    7,857
    5773
    10158
    Do they have to be 303?
    Easy cheater way to do shit like that is buy some gauge pins or perforator pins.
    .09" perf pins on mcmaster are $5 each, gauge pin $3.xx
    Or turn them down in steps and polish to size. Or buy some bigger stock and take one big cut and then polish to size.
  24. Likes Bobw liked this post
  25. #18
    Jan 2006
    Florida
    121
    6
    Not enough clearance between cutting tool and nose of the live or dead center in the tail stock.
  26. #19
    May 2012
    Indiana
    990
    181
    356
    Quote Originally Posted by berol View Post
    All lathes have that problem. Best to make a different tool. Narrow and long. A lantern tool post and matching tool holder might do it too. A photo of your attempts would go a long way in describing the details of your setup.
  27. #20
    Sep 2015
    Ohio
    1,154
    707
    1144
    The end of the bar doesn't have to be the end of your part.
  28. Likes Bobw, TeachMePlease liked this post
