bend radius vs strength
Likes Likes:  0
Results 1 to 6 of 6
    Jan 2007
    Florida
    1,162
    140
    423
    Default bend radius vs strength
    forming 1/4" a36 into a channel. force will be on the web with the flanges supporting. question: will there be a noticeable/measurable strength difference in relation to the bend radius? googled but didn't come up with anything
    ie: is a 1/4" radius stronger, weaker or immaterial vs a 1/2" radius
    Jul 2009
    NW Illlinois USA
    430
    102
    136
    Smaller radius may be stronger/stiffer if the smaller radius allows the force to be applied closer to the web. If I understand your question. Sketch would help.
    Dec 2008
    New York
    10,235
    2657
    Quote Originally Posted by cg285 View Post
    if too cold worked or too small a radius ductility goes down where possibility of cracking increases. sometimes cracking is not visible but under load part can suddenly fail. i wouldnt try for max strength and have no ductility where part could suddenly snap or break with little warning under load.
    .....some cold rolled steel you cannot even bend without it cracking. hot rolled steel becomes cold worked the more you bend it cold
    Oct 2009
    near Seattle, Washington, USA
    1,456
    501
    800
    Another thing to consider is bending across the grain of the sheet vs. bending in line with the grain. If you're bending in line with the grain you need a larger radius to prevent cracks along the bend.
    Dec 2008
    New York
    10,235
    2657
    it can be really inconvenient when a part under load suddenly fails or snaps into pieces.
    for example a grade 8 steel bolt slightly bent so if you straighten with a hammer or press the same bolt looks ok and can snap under load with no warning. seen it many times. parts with low ductility basically are brittle and easily snap or break with little warning
    Jan 2007
    Florida
    1,162
    140
    423
    Quote Originally Posted by DMF_TomB View Post
    what i was thinking
