Bending Very Thick Ar500
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Apr 2020
    CANADA
    Quebec
    6
    Default Bending Very Thick Ar500
    I want to use a press brake to bend 1.5" thick Ar500. The dimensions of the plates are 16" by 16" and it will be bent at various different angles. What sort of tonnage am I looking at?
    Langley, B.C.
    1,766
    383
    1032
    You're going to need 200+ tons for sure--depends a lot on how wide your bottom die is. The tonnage required
    varies depending on the width of the bottom die. The calculator I use doesn't show AR500 so I have no hard
    numbers. The other thing you're going to have to consider is point loading--a 16" wide part in a 12 ft. wide press
    will really concentrate the load...
    Accurpress Tonnage Calculator
    May 2011
    New Jersey
    649
    14
    220
    As stated, you need a large bottom die opening. Standard is 8x thickness.
    If you are bending a radius, most press brakes dont have that much depth at the cylinder frame area, to be able to bend directly under the cyljnder. Most have less then 12 inches. So it will be hard to find a brake that will do that kind of small job.
    Feb 2014
    Cartersville, Ga
    298
    109
    158
    Quote Originally Posted by Bondo View Post
    Most meaning the last of the American made machines. The rest of the world pretty much starts at 16" throat depths.
    Jun 2013
    Buffalo NY USA
    510
    332
    269
    Last time I did anything like that was a very large bottom die and 750 tons... preheated the plate just to dull red before bending
    May 2011
    New Jersey
    649
    14
    220
    Quote Originally Posted by Fish On View Post
    Yes straight in, but if you measure on an angle. A lot of them get smaller. Like my brake has 12 1/2" clearance straight back but only 8" if you went on a 45* angle.
    Just things to consider when bending
    Oct 2005
    17,705
    Quote Originally Posted by SirFlamenco View Post
    Sounds like a good job for a bulldozer.
  8. Likes Ray Behner, Ries liked this post
  9. #8
    Oct 2014
    Arkansas
    199
    45
    Yes. AR500 takes a lot of tonnage. Press brakes want max tonnage over at least 2/3 of bed width.
  10. #9
    Oct 2014
    Arkansas
    199
    45
    No, that only applys up to 3/4" thick. Above that is 10x material thickness.
  11. Likes Fish On liked this post
  12. #10
    Feb 2014
    Cartersville, Ga
    298
    109
    158
    I'm not following on the angle part.
  13. #11
    May 2017
    FINLAND
    2,155
    583
    998
    https://ssabwebsitecdn.azureedge.net...20151126081119
    Already in bed so I’m not going to dig out calculator
  14. #12
    Oct 2011
    CANADA
    British Columbia
    638
    54
    400
    Bending AR plate is always risky. If you can determine the grain direction of the plate that can help to prevent fracture.
    In my previous life as a brake operator I initially had zero experience with the stuff. One day we for a job bending some 3/8th AR plate about 8 feet long. I figured it would be a difficult push and used a wide bottom die around 3 inches. A millwright was helping me and after we had clamped the plate I picked up the foot control and pulled it out to its full reach. The millwright asked what I was doing and I said for him to stand back. His eyes bugged out as we listened to the creaks as the plate did the bend.
    I had only a few years experience and the next day I described bending this stuff to an old guy who ran a placer mining equipment outfit. He expressed surprise that we bent 3/8 plate and said I was lucky. He recounted that years ago at Dominion bridge in Vancouver an operator was bending AR and the plate fractured. The man was standing in front of the plate as it shot out and decapitated him. General policy was not to bend any AR plate over 1/4 thick. He suggested that the customer obviously knew that and sent the job to us in the hopes we would bend it.
    Be safe.
  15. Likes rcoope liked this post
  16. #13
    Jul 2004
    Southeast Michigan
    6,667
    250
    1569
    You will need a shit ton of capacity for that. I have no conversions for shit ton to actual tonnage.
    In other words, if you have to ask, you don't have enough.
    If fact, I don't know anyone that would take that bend on. Even if they had sufficient tonnage, it would be spread over a large length, and putting point loads on a giant press break is a recipe for destruction.
    I used to routinely bend AR, and it doesn't follow the rules.
  17. #14
    Nov 2009
    Massachusetts
    437
    143
    I don't know if this applies to AR500 steel, but traditional "armor steel" in general could only be punched very slowly. I'd guess that this would apply to bending as well.
  18. #15
    Mar 2005
    Kansas
    7,895
    486
    3757
    I want to use AR500 to bend a press brake.
    There. Fixed it for ya.
  19. #16
    Langley, B.C.
    1,766
    383
    1032
    Quote Originally Posted by snowman View Post
    ...I don't know anyone that would take that bend on. Even if they had sufficient tonnage, it would be spread over a large length, and putting point loads on a giant press break is a recipe for destruction...
    Just to qualify that bit, the amount of point loading that a press can handle is directly related to its capacity.
    A 200 ton point load in the middle of a 750 ton press bed would not likely cause problems but if you apply
    the same load on a 250 ton press and you're asking for trouble...
  20. #17
    Jul 2006
    Hillsboro, New Hampshire
    9,222
    2187
    6383
    No further comment from the OP. It might help if he were to explain why he wants to bend such thick/small pieces of a difficult metal.
    How does AR500 take to welding? If you can accept the HAZ in the weld zone, maybe a better option than trying to bend it?
  21. #18
    Sep 2015
    483
    23
    206
    Start with a 16x16x16 block of ar500 and machine it out.
  22. Likes lumley32 liked this post
  23. #19
    Nov 2003
    5,406
    188
    1803
    Sounds like a job for explosive forming to me. Suggest you contact Jamie and Adam. Lots more fun that way.
  24. #20
    Sep 2005
    il.
    6,676
    31
    1242
    I think maybe a billion
    in fact it sounds like that will take the most powerful press ever
    better get with the president
  25. Likes lumley32 liked this post
