chevy43
Stainless
- Aug 28, 2004
- Central CAL.
I want to make a temprature compensator out of some material that exspands as it cools.
I want it to work between 100 to 250* F.
It is a compression compensator for a model aiplane diesel.
On thease little engines the timing is adjusted by the compression ratio on the contra piston and they are very sensative to temprature.
I want to encase the materiall above the app. 1/2" contra piston and the adjstment screw to lower compression as the engine gets hot and increase it as it gets cold. The idea is similar to a wax pellot in a thermostat.
Maybe I can come up with a simple compact way to do this mechanicaly from an expanding material....
Any ideas?
Treven.
Any ideas?
Treven.
