Best alum alloy for bending up an enclosure
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Jul 2006
    rochester, ny
    1,931
    393
    544
    Default Best alum alloy for bending up an enclosure
    I need to make bend up small (12" x 12" x 5") box to hold small cnc router control stuff. Wondering what grade will be easiest to bend. and still not too gooey to mill and drill cutouts?
    Don't have a brake, will be bending over wood blocks. Primitive, but it's worked ok for me with steel sheet in the past.
    Jan 2014
    Temecula, Ca
    2,908
    1301
    3745
    3003 or 5052
  3. Likes PlasmaOnTheBrain liked this post
    Oct 2005
    15,661
    If the whole reason for going with aluminum, is the ease of routing afterwards, might look at having a steel sheet laser/waterjet cut instead.
    May 2004
    2,510
    886
    1637
    Quote Originally Posted by Larry Dickman View Post
    3003 or 5052
    3003 H-14. Fantastic for forming and welding.
  6. Likes Ray Behner, PlasmaOnTheBrain liked this post
  7. #5
    Jul 2006
    Hillsboro, New Hampshire
    7,756
    1813
    5459
    This page: Which Aluminum Alloy Bends Best? - Clinton Aluminum
    has useful data showing alloy, temper, and relative bend inside radius per common thicknesses. You can use it to figure out what alloys-tempers that are easy to get in your area would have for bend properties.
    Generally, softer will mean worse milling and drilling, but if needed you can use coolant or a spray mist to keep cutters clean(ish).
  8. Likes Pathogen liked this post
  9. #6
    Apr 2012
    AR, USA
    961
    20
    175
    You can find charts online giving maximum recommended bend radius for a given thickness material. The softer the material, the easier to bend and more PITA to mill and vice versa. You will probably want one of these common materials listed from hardest to softest: 5052-H32, 3003-H14, or 1100-H14.
  10. #7
    Sep 2006
    SE PA, Philly
    5,340
    997
    1778
    It's interesting that the Clinton website shows that 3003, 5052, and 6061 are all rated "A" for cold working and "D" for machinability in the annealed state.
    Heat treat them and the 3003 and 5051 are rated "B" for cold working, and 6061 is rated "C", but all of the machinability ratings rise to "C". If you believe such things.
    The folks here seem support these ratings. It strikes me that, unless you want to anneal large sheets or heat treat your panels, purchasing 3003 or 5052 in HT form gives you pretty good formability and ok machinability.
    FWIW, some popular NEMA enclosures are made from 5052 with HT to H32. Per robert123's point, this is likely the hardest of the easily formable alloys.
  11. #8
    Langley, B.C.
    1,702
    352
    996
    We have done a ton of forming work over the years and I can say without hesitation that 5052 is the
    best overall alloy for general work. It forms easily with relatively tight radii and is easy to work when
    cutting or drilling for access holes or ports. 3003 is pretty soft and easy to mark when you're working
    it--would definitely not be my first choice.
    If you're doing a bunch of these I would highly recommend laser cutting before forming. We used to
    make large electrical enclosures--up to 60" x 60" x 144"--and we would have all the individual panels
    laser cut before forming. You can even cut tabs and slots for locating specific parts--a little more work
    up front but it made the assembly process a breeze...
  12. Likes ranchak, Dan from Oakland liked this post
  13. #9
    Sep 2005
    Oakland, CA
    2,503
    303
    673
    5052-H32 without a doubt. kinda gummy to machine, but not anything at all like 3003.
  14. #10
    Jan 2017
    Oregon
    2,672
    472
    1895
  15. #11
    Nov 2003
    5,051
    176
    1559
    I have had good luck with plain old 6061. I used thicknesses from 0.040 to 0.063". No problems cutting or bending even with import 3 in 1 sheet metal machine. And I have done it by hand as you anticipate. It also drills easily and it is dead easy to punch holes in it with chassis punches and other types of punches. I have made hundreds of custom chassis and have never seen a reason to look for another alloy.
    But you may want to consider just buying a stock aluminum chassis. They are available in a wide range of sizes.
    Internal Error
    (Note: This is a link to a DigiKey search for "aluminum chassis" and it does work. I do not know why it shows up as "Internal Error' but you can click on it.)
    and
    https://www.mouser.com/Enclosures/En...hassis&FS=True
  16. #12
    May 2014
    Massachusetts
    124
    8
    32
    5052-H32 or 3003-H14
    If you must use 6061 make the bend radii BIG!
  17. #13
    Jul 2006
    rochester, ny
    1,931
    393
    544
    Thanks for the replies, 5052 or 3003 it will be!
  18. #14
    Sep 2002
    People's Republic
    3,354
    281
    2196
    6061 is usually T6 and would be described as not bendable. If you found it in a softer temper or as mentioned used a big radius.....
    5052 is usually, uhhh, H32? and works nicely without being squishy
  19. #15
    Oct 2007
    SPAIN
    3,562
    1999
    1297
    5082 1/2 hard in the UK - great mtl to use. So 5052 would be very similar.
    Stay way clear of 6061 (6062) in the UK if bending. You can bend it but anneal it first, but it still needs a big rad and you want to bend with the grain
  20. #16
    Nov 2003
    5,051
    176
    1559
    He is talking about making an electronic enclosure. To my mind that means a fairly thin gauge: in my post above I mentioned thicknesses from 0.040 to 0.063". I will repeat my claim that, in those gauges, it bends quite nicely. NO PROBLEMS!
    Now I would not recommend bending, straightening, and bending it again in the same place. In that case, all bets are off. But a simple 90 degree bend with a normal radius really is OK. I have done hundreds of such bends with no problems.
    Now, if you are talking about 1/4" or 1/2" and a small radius, then YES you need a better alloy.
  21. #17
    Mar 2009
    Eureka, CA
    3,773
    751
    1306
    Not what was asked...but there are quadrillions of enclosures floating around on places like eBay, and they're cheap, well built, gasketed and available in steel, aluminum as well as plastic. Can't imagine trying to make one versus buying one..and I make all kinds of goofy shit.
    Stuart
  22. Likes NRDock liked this post
  23. #18
    Nov 2003
    5,051
    176
    1559
    I already pointed that out and even gave some links. But, from experience, I can tell you that the usual reason for making one is that, even with the wide variety of sizes that are available, you may not find one that meets your requirements. Too short/too high. Too wide/not wide enough. Not the right shape. The cover does not work the way you want. Etc. Been there many, many times. So you make one.
    Quote Originally Posted by atomarc View Post
    Stuart
  24. #19
    Mar 2009
    Eureka, CA
    3,773
    751
    1306
    Sheesh..didn't mean to rain on your parade.
    When I say 'enclosure', I'm not referring to a little aluminum hobby box but more to an item like this. Hoffman A-241206 24" x 12" x 6" Steel, Type 12 / 13 Wall Mount Enclosure. New! 7835102806013 | eBay
    A tad tough to make on the bench with a rusty pair of vice-grips.
    Stuart
  25. #20
    Sep 2002
    People's Republic
    3,354
    281
    2196
    Quote Originally Posted by EPAIII View Post
    shrug
    I select unmarked aluminum from my bin by putting it in the press brake. If it bends it is 5052, if it breaks it is 6061, without exception
    even if 6061 T6 bends at .06 it is at the limit of its ability to do so.
  26. Likes rcoope, Fish On liked this post
