motion guru
- Dec 8, 2003
- Yacolt, WA
I have a machine section that I am working on that is a high maintenance item for our customer that involves raising and lowering a set of rolls every 20 seconds. There is more to it than that, but trying to keep this simple.
One section of rolls is raised / lowered 12 inches by means of a roller chain on two 1 inch pitch sprockets spaced about 10 feet from one another on a common hoist shaft.
Weight of rolls and associated frame equipment is about 2500 lbs and the machine is presently requiring new chains and sprockets about every 6 months.
Operation is:
Lower Load 12 inches over 1 second
Hold Load for about 2 seconds at the lowered position
Raise Load 12 inches over 1 second
Hold Load for 16 seconds at the raised position
Repeat 24x7
This describes 1 side of the machine, there is an identical mirrored set of rolls on the other side of the machine that move in the exact same manner.
Hoist shafts on both sides of the machine are parallel to one-another and are connected to a common gearbox through two additional right angle gearboxes. So a single motor/gearbox + 2 more gearboxes raises and lowers both sets of rolls (which makes keeping them synchronized easy)
The right angle gearboxes require rebuild every 12 months also.
The present motor / drive system is already hitting over 200% of motor current to raise the rolls and my challenge is to speed this whole process up by about 30%.
AND . . . there are multiple identical sets like this. It is a common German Machine design in the industry it is in and I am reworking the entire line to address throughput and maintenance issues like this.
So . . . I am thinking that a counterbalance might be in order for the raise / lower carriages that relieves weight from the lifting chains and doesn't add any inertia to the payload.
I would like to use a pneumatic cylinder or perhaps an air-over-oil cylinder setup. The thing will cycle 25,000 times a year and I would like to get a few years life out of the cylinders. Even if I relieve only half the weight it would seem like this would extend chain life and reduce drive/motor load considerably. Each cylinder would optimally lift about 1000 lbs and with crappy plant air, you cant count on anything consistent above 50 psi . . . so the cylinders would need to be roughly 5 inch bore.
Any thoughts on a good cylinder choice? Seems like a double rod extended cylinder would last longer. Trunnion mount? I am a bit of a novice when it comes to pneumatic / hydraulic cylinder design for high cycle low friction applications.
Operation is:
Repeat 24x7
