Best Benchtop Lathe - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 74
  1. #41
    Sep 2008
    Canada
    1,504
    590
    586
    What dalmatiangirl is probably getting at it the idea of difficulty having any lathe on casters. Makes it problematic to get/keep the ways untwisted. There’s a few lathes, like a Colchester Chipmaster that can, because of three point mounting be on casters, but then you get into risk of tipping.
    L7
  2. #42
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,715
    2825
    1739
    Quote Originally Posted by tartcha View Post
    Yes, 5” 1500lb ones, but mounted to the sides of the legs or base of brackets, the lathe will sit on leveling feet when in use. I just need to move it every so often to access my air handler, humidifier and hydronic system.
    Hitting some space issues in the garage...
    I've seen a few caster mounted machines that were done well, on a low slung cradle where if a caster failed the machine did not tip. There have been several threads on here involving face planted lathes due to caster failure. 1000 lb, 2000 lb, you cannot lift either, seems to me the effort to move either is the same.
  3. #43
    Mar 2013
    UNITED KINGDOM
    2,734
    3028
    1686
    Its a tough choice.
    Something with a name swinging say 13" weighing 1.5 tons odd that bolts to floor or a maximat that uses genuine paper shims to align the headstock from factory
  4. #44
    Jan 2005
    Victoria, Texas, USA
    4,567
    3051
    1242
    A Wheel arrangement like in this picture would be the best to me. Just a thought.
  5. Likes M.B. Naegle liked this post
  6. #45
    Feb 2021
    Washington
    16
    Sorry so newbie question, if it sits on threaded leveling feet when in use why are casters a problem, totally get one could break during moving but I may not understand fully.
  7. #46
    Jan 2003
    Columbia Missouri
    903
    62
    176
    Some may have missed that the lathe is on threaded feet when in use- and that you plan to level it after each move.
    But...A lathe on a bench or stand is top heavy, and can go over fast. Some caster weight ratings seem to be based on optimism, not engineering. They can fail. It sounds like you will be moving the lathe straight out, so the momentum will be towards you, and on the narrow aspect of the base. If the caster fails, over it comes. OR__ if you hit a stray a stray bolt and the caster stops turning- over it comes.
    You need to think about the way casters are mounted and swivel. Most casters are mounted under what they support so we do not trip over them.
    Here is a 6 inch swivel caster rated for 1200 lbs. McMaster-Carr
    When mounted to the leg of the stand, the swivel point of the caster is 2 3/8 inches inside the edge of the stand (or 3 5/16 if mounted the other way). If the wheel is rotated under the stand, the axle is another 2 1/16 behind that. Lets say you bench is 32 inches deep- about an arms length. If the center of gravity is in the middle, it is 16 inches from the edge of the bench- but the casters contact with the floor is 4 7/16 inboard of that, and only 11 9/16 inches from the center of gravity. If the caster is mounted the other way the axle is inboard by 5 3/8 inches and only 10 5/8 inches from the center of gravity.
    More to think about than it first appears.
  8. Likes geckocycles liked this post
  9. #47
    Feb 2021
    Washington
    16
    Ahh yes, totally agree, I plan on doing the threaded leveling feet in the legs and then the casters outboard (sticking out on the length sides) that should put them 4-6” out of the edge of the lathe. Will not be using cheap amazon ones for this.
  10. #48
    Jun 2012
    Michigan
    13,332
    4524
    4798
    QT the casters outboard (sticking out on the length sides)
    Out at the length ends won't help avoid top-over as well as sticking out at the narrow way.
    Agree at the narrow they are something to trip over.
  11. #49
    Oct 2005
    21,070
    "levelling each time you use it"......Uhm yeah, like that's gonna happen.
    Put it on larger wheels so you could run it while doing 80 mph down I-95....
  12. Likes Demon73 liked this post
  13. #50
    Apr 2004
    Modesto, CA USA
    8,409
    1592
    Best benchtop lathe? I would have to say the Rolls Royce of benchtop lathes was made by, Rolls Royce.
    Bill D
    Rolls Royce Lathe
  14. Likes Jim McIntyre liked this post
  15. #51
    Jun 2006
    Spokane, WA
    721
    207
    Where in the PNW?
    PM me, as I've a couple of possibilities for you.
    jack vines
  16. #52
    Virginia
    18,885
    7561
    11641
    Quote Originally Posted by lucky7 View Post
    ...a few lathes, like a Colchester Chipmaster that can, because of three point mounting be on casters, but then you get into risk of tipping.
    L7
    Not if you apply a fairly common fall-back, no.
    Be it a bar stool, shop stool, large surface plate, or a 10EE... one honours the uber-stable 3-point "plane" but then also..
    ...adds two if not more OTHER points spaced off the deck atop a thin layer of ignorant AIR.. so as to NOT bear ANY load atall "normally", but only allow a silly millimeter of tilt until they DO bear. Some have a spring or a thicker bit of resilient material than the "primary" points.
    Thereby preventing tipping getting any significant head-start ...if one corner of a shop stool / bar stool, large-area surface plate, kitchen or sidewalk bistro two-fer tea table, or a 3-point whilst working lathe is tilted by enough that those "limiter" stop supports come into actual contact.
    Not rocket science to put into effect.
    Not a hazard to accuracy, either.
    Not until some well-meaning person ignorant of their true purpose comes along and tries to shim or adjust the "backup" anti-dis-assed-her topple-over-preventer points ... as if they were MEANT to be equal players in sharing the load!
    Which they are NOT.
  17. #53
    Jun 2012
    Michigan
    13,332
    4524
    4798
    I don't know if this has been mentioned but the through-hole can be important for a short/any lathe.
    Doing gun work the front sight may not fit through a small headstock bore, and the barrel length may be too long for between centers or in a steady.
    Plus be sure you have the thread choice you think you may need.
  18. #54
    Feb 2004
    peekskill, NY
    26,586
    6032
    Trouble with casters is, well, they 'caster.' When you pull an item forwards (say, away from a wall) the wheels caster to the rear. Lathes (southbends in particular) tend to be front heavy anyway. With the legs swung to the back it doen't take much floor debris or irregularity to 'trip up' the rig, and tip it over on the front.
    Make the caster base larger in area? "Oh no, we're trying to *save* room by shuffling shit around in the shop..."
  19. #55
    Virginia
    18,885
    7561
    11641
    Quote Originally Posted by jim rozen View Post
    Casters routinely as sunshine in summertime fail in two "main" ways. The wheel sheds a "tire" off the hub or at a two-type of material bond line.
    From side force.
    Or the usually sheet-steel "body" collapses to one side. Also from side force.
    Machinery skates not aligned with the desired direction of travel, OTOH?
    JF SIT there. Stubbornly reminding you they ain't budging until YOU intentionally point 'em a-purpose.
    The negotiated compromise on my mill and shaper is to fix-mount the buggers close to center mass like an oxcart or the paddle wheels on a high-manueverability sidewheel steamboat that can spin any direction sitting still in its own length OR whilst in-motion.
    THEN all I have to do is slack the front-side jackscrews to unload the arse-side cross bar, lower the machine onto the Vestil 10K multi-roller with swivel top plate.. and tug it about like a nosewheel aircraft on a ramp.
    No real risk.
    Even if it wants to tip? Those leveling jackscrews are only slacked to under a tenth of an inch off the deck, 90%+ of my nice flat floor.
    10EE's are similar on three-point skates their pivot bolt also the leveling jackscrew via some simple washers and multiple-nut foo.
    I'm VERY badly flocked only if ever I get one near the built-in 4-inch drop downramp just inside the 18-foot roll-up door. Ergo I do not!
    Otherwise safe as moving a grand piano on THEIR special carriers. AFTER sweeping the floor.
    Of course.
    Been "on my head", first-year of production Corvair. Before Ralph Nader was yet assembled from a kinderfartrun class pooling the toys outta the squad's cracker-jack boxen. Or maybe it were the caramelized peanuts and congenital opportunism?
    Back injury from an early age onward kinda makes a believer outta yah as to the potential for unexpected consequences of tripping over what had been thought to be but the silliest of trivia. And was not trivial ENOUGH.
    See also M-151 suicide bad roll kit, 1/4 ton 4X4, crossbreed between the Devil and Hun-ery Ford's as revenge for his beloved Weird Adolf loosing the war. First gen had the same penchant for wheel tuck-under as the early Corvair had.
    Both got at least an improvement, if not a full fix.
    Injured stayed injured. Dead stayed dead. Metal stayed scrapped.
    Not a situation as needs further statistical proofs, is it?
    Go though and start WISER!
    Casters are for beans or kvetching fish that got away.
  20. #56
    Feb 2004
    peekskill, NY
    26,586
    6032
    From side force.
    Point being, it's usually not a caster failure. It's a design flaw, built into the concept of 'we need to keep it all tiny and compact because we don't have enough
    room to put stuff because the shop is too small and we can make it bigger by shuffling things around on wheels.' And the design for where to put the casters
    suffers the problem mentioned above. Push it one way, it tends to tip that way. Push it the other, it tends to tip the other way. One way tends to tip over on
    the face of the lathe because of the natural heavy front of those things.
    Lathes belong on the floor. Stop putting to much stuff in the shop. This solves the problem at the start of it.
  21. #57
    Dec 2016
    Washington
    347
    97
    98
    Sometimes you just have to take it apart to move it. The dreaded H.F. car dollies work well for individual lathe parts, as long as they are securely strapped on.
  22. #58
    Virginia
    18,885
    7561
    11641
    LOL! Look who is kvetching about "space"!
    "TDS" hadn't given DJT rent-free space in your HEAD for the rest of your days? Sized to cover the needs of a whole dam' 36-hole dual-redundant golf course and holiday resort with a casino?
    You would have enough spare space to house YOUR bikes, Jay Leno's wheels collection ... and still be able to TiG weld an entire Graf Spee class dirigible airframe in one go!
  23. #59
    Virginia
    18,885
    7561
    11641
    Quote Originally Posted by morestainless View Post
    Got more than a dozen of those HF "furniture" dolly thingies. A few more, yet of better vendor all steel ones, larger. Heaviest loads are one-each Reliance motor or a K&T milling head, or K&T slotter. Burke mill and the pantoengraver dont weigh much atall.
    But for the 10EE's and the "real mill". No Fine WAY I would use casters!
    I use these on the uber-flat concrete:
    3300 lb skate
    These on either that or the asphalt of the driveway:
    4400 lb skate
    And a Vestil 10,000 lb-rated multi-roller swivel-top skate with towbar. For steering. Two Vestil 5,000 pry dolly do the gross shifts. Pair of toe/combo jacks, pair of trolley jacks. Handful of bottle & scissors jacks, collection of wedges, pry bars, and pinch bars, all sizes, plenty of shims, straps, other cordage, chains, chainfalls, chain hooks, clevises, other accessories, both hand and electric winches, electric hoist too.
    I didn't buy it all in the same year.
    Took annual half-price promo and such. i'm on Northern's premium "free shipping" plan. it saves me money. Plenty of it!
    Almost NONE of it bought "used" though.
    Strap get used ONCE. Inspected, downgraded. Seldom sees a third go.
    I've chikn'd-out and bought NEW arredy. Chan get's checked as well. Chain is cheaper by the full tub from a supply house than by-the-foot at Big Box, BTW. And you can get better-grade chain for the money. Do NOT skimp on clevises, links, loops, hooks, couplers, eye-bolts, EITHER! Not At ALL!
    Cheap s**t right there is where you break stuff ever' dam' time.
    They say life is cheap? Mine sure TF is not!
    Supply and demand thing. Got less of life still in inventory? Back-orders nor refunds not accepted? No refills in stock? Even a fine Wife can only do but so much rebuild?
    Price of the dwindling stock of "life" remaining goes UP. Not DOWN!
    BTW: The Vestil goods aren't really any better than the Northern goods.
    Northern is good enough. H-F they were never. I just do not do rigging OFTEN enough to wear them out. Can't really justify Hilmans or the best German-made ones a full-time pro would use, EITHER.
    Owning the mostly-Northern menagerie, outright, has proved cheaper than renting. And waaay safer and more convenient. If only because I KNOW I HAVE IT on any given short-notice day or minute.
    And I know if some prior a-ho has abused the gear! Or NOT!
  24. Likes morestainless liked this post
  25. #60
    May 2003
    5,417
    22
    693
    termite, you have never made a thing on your junk broke down Monarchs, or your dumb ass Burke mill.
    And again you are sitting on top of a dead thread, because of your addiction to post and tell bullshit stories "in others threads".
    You have constantly lied about you background, and bullied off the forum very knowledgeable machinist, whose only crime is calling BS on you entire troll act.
    But, in a self destructive act, that defies explanation, you stupidly decided to attack me, a working professional, that is simply not going to back down from a worthless piece of shit like you, or your dwindling friends.
    just an update, the termite studies continue.
  26. Likes dfloen liked this post
