Best crimper for uninsulated terminals
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
    Sep 2010
    Oklahoma City, OK
    5,650
    1094
    2474
    Default Best crimper for uninsulated terminals
    What's the best crimper for this type of connection? Ideally something moderately priced and not the mickey mouse red/blue/yellow thingy.
    Sent from my SM-G981V using Tapatalk
    Nov 2003
    6,069
    219
    2095
    Not the best by any means, but you can spend $200, $400, and more. I have used these Vaco crimpers for many years, for both professional and personal work and have never had a bad crimp. And the handles are nicely padded which is great if you are going to spend hours crimping.
    What I look for in an inexpensive crimper for the un-insulated wire terminals is the type of jaw that these have.
    In this closeup you can see the bottom jaw in the photo is where the split side of the connector goes. It fits closely and prevents that seam from opening. The top jaw pushes the metal of the connector into the wire exactly enough to create a gas tight joint so it will not pull out or corrode. There are more expensive tools and dies that make a different style of crimp, but these have worked for many thousands of connectors for me.
    Another thing that I look for in any crimping tool is a positive stop. A positive stop tells you that enough pressure has been applied but it also prevents you from applying too much. If the pressure is too little, the wire can just pull out. If the pressure is too much, then the wire will be crushed too far and it can and often does then break at the point where the crimp starts. The correct pressure is a must and this tool tells you that when the rear-most point of the jaws, near the soft plastic handles, comes together with a click.
    It has been a while since I purchased them, but I believe they were about $20 or $25 back then. Several, perhaps many companies make similar ones. I like to stick to the known, name brands, not the unknown imports.
    Vaco is a good brand. After 30 or more years of use, mine have a slightly loose rivet holding the halves together. This is probably more due to my using them to cut small screws to length than for their use in crimping. They still work well for both these purposes. The wire stripper section never was any good and has become almost totally useless with this wear. The tool of this type of construction with the best wire stripper I have is by AMP. Mine is about 40+ years old and will still strip solid wire - not so much with stranded. But then, I have multiple wire strippers which I usually use.
    Other good brands include: 3M, AMP, Amphenol, Belden, Cinch, Greenlee, ITT, Klein, Molex, Switchcraft, Weidmuller, and more. Stay away from obvious Chicom or unknown or house brand tools in local hardware stores or unknown, internet sellers. And I do not know if all of the above companies make this style of tool. Good places to purchase them would be McMaster, Grainger, DigiKey, Mouser, Newark, and other electronic suppliers.
    Sep 2010
    Oklahoma City, OK
    5,650
    1094
    2474
    I've been using my Knipex ferrule crimpers to good effect but it's not ideal. They have a similar jaw profile to what you suggest.
    May 2020
    Minnesota
    537
    214
    226
    Lineman's pliers with built-in crimpers work great for non-insulated stuff. Or insulated terminals too wherever the insulation factor doesn't make a lick of difference, which I find is much more often the case than not.
    Klein is the way to go. There is a reason people in the trades still call lineman's pliers 'Kleins'. Oil them once in a while and they'll stand up to years and years and years of cutting MC cable and small machine screws. Southwire stuff seems okay too. Avoid Ideal tools like the plague; everything they make is utter garbage.
  5. Likes BT Fabrication liked this post
    Mar 2006
    Wisconsin
    1,305
    14
    472
    My "Go To" wire crimper is the same one EPA111 uses. It works great in tight places and never makes a bad crimp.
    For more open spaces I use Klein Long nose tool like this
    https://www.homedepot.com/p/Klein-To...80702-23-12140
    Crimping is done in the section nearer the hand grips. It also does a fine job, it just takes more room to maneuver the tool
    Jan 2005
    Houston
    7,233
    1369
    4236
    My favorite by far is the Klein 1006. Long handles for leverage and not a lot of extraneous features:
    https://www.homedepot.com/p/Klein-To...1006/203433805klein-1006-pliers.jpg
  8. Likes 4GSR, rbent, D Nelson, awander, jmead and 2 others liked this post
  9. #7
    Aug 2004
    Virginia
    2,930
    241
    1374
    I have never liked the crimpers that have the crimping section between the handles. They require you to pass the handle over the job which can be very frustrating in tight quarters.
  10. Likes 4GSR, paulz, Gordon Heaton, jmead, TheOldCar liked this post
  11. #8
    Mar 2007
    wisconsin
    163
    245
    151
    Sta-Kon WT111M, or an equivalent.
  12. Likes B1 SCOTT liked this post
  13. #9
    Nov 2009
    Massachusetts
    776
    279
    I have one of these, bought many years ago, and made by Buchanan, the inventor as I recall. Works very well. But not really for installation of in-line barrel splices. Buchanan still makes these, but far more complicated models intended for production.
    Buchanan's patents have long since expired, and there are many makers of the original design:
    4-Way Crimping Tool AWG 22-10
  14. Likes 4GSR, dgfoster liked this post
  15. #10
    Jul 2007
    UNITED KINGDOM
    5,513
    3471
    2853
    My 40 year old ones are from Walsal Conduits, who no longer exist in the form that they were. Befroe that I used AMP ones. The important part of both is that they have compound leverage and a ratchet, so you can get surricient leverage and you can't release them until the crimp is fully formed. In both cases the crimping pliers were used with crimps made by the plier's manufacturer.
    Pliers types are a liability when crimping connections for things like power station current transformers that can have an open circuit voltage of 5000V and 5A current, which will need demagnetisation and recalibration if they are accidentally open circuited.
  16. #11
    Mar 2009
    6,426
    125
    1248
    Quote Originally Posted by Cole2534 View Post
    The red/blue/yellow color code jaw tool is not strong enough to bend the metal. That lug has .050 thick rolled pieces. The insulated connector lugs
    are about 1/3 that thickness. Those thick connectors like this one I usually solder to or use small screws and nuts. If you crimp then ...
    https://www.globaltestsupply.com/pdf...-datasheet.pdf
  17. #12
    Feb 2004
    peekskill, NY
    27,427
    6392
  18. Likes B1 SCOTT, Scottl, gary-sc liked this post
  19. #13
    Jan 2005
    Houston
    7,233
    1369
    4236
    The T&B 111 and Kelin 1006 are essentially identical tools, but the Klein is 1/2 the price.
  20. Likes wheelieking71 liked this post
  21. #14
    Oct 2010
    Maryland- USA
    5,021
    2446
    3127
    It depends on the size you need to do.
    Get above 8's or so and you need to start upping your game.
    I use an Amp Rota-crimp.
  22. Likes BT Fabrication liked this post
  23. #15
    May 2020
    Minnesota
    537
    214
    226
    Quote Originally Posted by Trboatworks View Post
    Burndy power crimpers FTW.
    YouTube
  24. #16
    May 2011
    New Jersey
    3,357
    373
    1910
    Quote Originally Posted by GregSY View Post
    This is basically what I use but has red grips. 1000s of crimps with no issues...wire does NOT pull out after using these.
  25. Likes awander, Steven-Canada, 1yesca liked this post
  26. #17
    Dec 2008
    Michigan
    150
    95
    62
    Dbl post. Apologies.Best crimper for uninsulated terminals
  27. #18
    Dec 2008
    Michigan
    150
    95
    62
    For the style terminal pictured ratcheting crimpers are best. They uniformly press the terminal barrel material around and into the conductor. They make for a very secure bond. We use these in the Electrical Lab in the Chrysler Tech Center to make OEM grade crimps.
    3107 DTCT Sargent Ratchet Crimping Tool | Waytek
  28. Likes Mark Rand liked this post
  29. #19
    Jun 2015
    CANADA
    Ontario
    535
    1546
    303
    Quote Originally Posted by plastikdreams View Post
    The red ones I have I got at home depot
    GB Gardner maybe
    Channel lock has similar too
    https://www.homedepot.com/p/Channell...-909/202304949
  30. #20
    May 2011
    New Jersey
    3,357
    373
    1910
    I'd like to put out there as well, the leverage is outstanding. There's no need to have to squeeze as had as possible, especially on cheap butt splices...it will literally tear right through the cheap plastic. This is nice because it's easy on the hands.
  31. Likes GregSY liked this post
