Best Hand Tapping Jig? Minimum 7" Throat Depth. What Model, Where to Buy?
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Feb 2014
    Sunny South West Florida, USA
    3,306
    11409
    3699
    Default Best Hand Tapping Jig? Minimum 7" Throat Depth. What Model, Where to Buy?
    First: Yes, I could just make one.
    But that's not how my company works. If it's going to be used in production, it's got to be traceable to a manufacturer, and have a part number so it can be reordered as necessary. So no, I'm not just going to work a Saturday and build a fancy one like some of you have.
    Second: It won't actually be used for a tap, it'll be used for a reamer, so something with a chuck for round tools would be useful, but I can make an adapter if need be (And then give the adapter a drawing and a part number and have it made by an outside shop, to follow rule number one).
    This is what I found on MSC: https://www.mscdirect.com/product/details/09491002
    Appears to be OK, the 7.5" throat depth is the minimum I can use.
    Any input on this one, or other models?
    Thanks for any help.
    May 2019
    Michigan
    692
    52
    247
    I can make you one and give you a model #, part #, BOM, serial # (001 ), and NIST cert.
    Just followin' rule #1......
  3. Likes TeachMePlease liked this post
    Jun 2012
    Michigan
    11,259
    3848
    3975
    A drill prees makes a great Tapper..and it can drill and tap...
    Feb 2014
    3,306
    11409
    3699
    Quote Originally Posted by michiganbuck View Post
    Needs to be benchtop, and as compact as possible. Trust me, I suggested a drill press. No go.
    Nov 2014
    Florida
    4,303
    1672
    2022
    No exp with this model as I've always used shop made ones, but appears "good enough", and about half the price of MSC.
    PRECISION HAND TAPPER
    Jan 2014
    Temecula, Ca
    3,188
    1378
    4163
    I bought one of those from Rutland years ago. I thought it worked pretty good. Real easy to keep taps straight and square when tapping by hand.
    I let someone borrow it. They must've thought it worked pretty good too cause I never got it back.
    Oct 2005
    17,241
    Quote Originally Posted by ChipSplitter View Post
    After the cheque clears....
  9. #8
    Oct 2012
    324
    124
    148
    I have the Enco version of that from way back when. It seems to work just fine. There's not much too them. If the tap is straight in the collet, the rest of it just has to spin.
    If it were my money, i'd probably get the $200 unit instead.
  10. #9
    Nov 2014
    Florida
    4,303
    1672
    2022
    Quote Originally Posted by TeachMePlease View Post
    WiIll you need 10 approvals, 3 meetings, and 2 weeks of emails to spend $200 on one?
    I worked at a place like that, and it is really not much of an exaggeration! Every purchase needed about 3 people, and a mile long email train back and forth to spend $50 on a tool.
    Our shipping department once lost a skid (yes a skid) of aluminum blanks for a production job for something like 2 weeks.
  11. #10
    Oct 2005
    17,241
    The "Best" ?
    How about a custom made job using a Harig air float endmill fixture ?
    Mounted on a stout column. Column base has adjusting screws at flange interface for precise leveling & squareness, and it's bolted to a Starret master granite surface plate.
    All would fit on a bench top....
    That should crank up the bean counters underwear a few notches....:d
  12. #11
    Feb 2006
    Indiana
    13,126
    720
    4067
    I have one of the tappers like the ones previously linked. Mine is the Phase II "brand," so it is the same generic Chinese copy of the USA-made Lassy tapper. I think it was about $150 around 15-20 years ago, so $200 today is fair. After I got mine, direct from Phase II, I saw the body was already drilled and tapped for a second collet rack. I was able to buy a second wood rack and set of tap collets from them. I keep UNC and UNF 2-flute spiral point taps in the collets ready to go. I think I have seen one or two of the Lassy tappers on eBay over the years.
    Anyway, I am extremely happy with my Chinese tapper. It is well made and accurate enough that I never had a reason to check it for accuracy. It sure saves time when doing several through hole tapping jobs.
    HAND TAPPER
    But, if you want to buy American, Lassy is still in business making the current iteration of the tapper.
    Lassy Tools-Products-HAND TAPPERS and TAP & DIE GUIDES
    Larry
  13. #12
    Aug 2017
    Connecticut
    39
    6
    If you want one that'll last under ongoing shop usage, it's hard to go wrong with the Lassy Tool tappers. They make a bunch of sizes both benchtop and free standing.
  14. #13
    Nov 2014
    Florida
    4,303
    1672
    2022
    I find it interesting that all of the ones listed in the 7.5" throat depth all come in at 37 lbs...?
    I mean, I understand all the dimensions *should* be close, but just odd the exact same weight (listed anyways). Surely some of the cheaper models are using skinny castings and / or cheaping out on the base... or something.
  15. #14
    May 2019
    Michigan
    692
    52
    247
    Tell your boss you need a power tapping arm.
    One of our subcontracters has one that can tap 3/4" NPT.....
  16. #15
    Nov 2013
    Eastern Massachusetts, USA
    5,301
    5090
    5115
    That looks like a decent one. The most important aspects are a straight, well-fitted spindle and a good adjustment weight so the action is smooth and true.
    PS: At home I use one bought from HF decades ago on sale. It needed some work on the tap holder retention spring and the addition of a balance weight but it's served well for lots of tapped holes.
  17. #16
    Dec 2008
    IL/WI border
    3,419
    1215
    1063
    I have one as in the links. Works just fine. Paying $500 for it would be ridiculous though.
  18. #17
    Oct 2013
    New Jersey
    1,175
    999
    The shop manager at my last job made one. It turned out so bad I tossed it in the garbage because it wasn't even square to the table, held the tap poorly and by my estimation cost us at least $1000 to make because he screwed it up at least 3 times. But then he claimed to be a precision tool and die maker with 30 years experience, so maybe its tougher to do than I thought.
  19. #18
    Nov 2006
    Southern California
    1,013
    7
    118
    I have used the Asian copies of the Lassy hand tapper and have been less than impressed. What a lousy not square lump of metal. We ended up with a Cedarberg hand tapper. The 780 has a 7.5" throat but is well machined and dead simple. It is US made and just works. The tap holders are machined from standard hex stock. So machining custom adapters is pretty easy.
    If you were making small stuff and could live with a 4" throat, the most used tapper at work is a Bauer Precision No. 110 hand tapper. I really like it for smaller taps (#10 and below).
  20. #19
    Jul 2004
    Reddington, N.J., U.S.A.
    3,323
    168
    278
    Quote Originally Posted by crrmeyer View Post
    Bauer went tits-up recently. Entire shop was sold at auction.
  21. #20
    Nov 2006
    Southern California
    1,013
    7
    118
    Quote Originally Posted by reggie_obe View Post
    Ugg. Well that stinks. Interesting that the web site is still up.
    Link to auction flyer.
    https://s3.amazonaws.com/koster-indu...er-Ebroc-1.pdf
    Looks like they were also selling the rights to make the hand tapper. I wonder if anyone picked it up? I sent an email regarding. We will see if it gets answered.
