I've decided to replace the tailstock spindle on my Sheldon lathe.
Lathe was in excellent shape when I acquired it, but the tailstock taper was badly boogered up so I cleaned it up with an MT reamer. Unfortunately, the extra depth required to clean it up completely forced me to face about 3/8" off so the tooling would seat correctly. Plus, it was shorter than it could have been from the factory- fully retracted I've got nearly a full inch of the spindle inside the barrel. So, I want to get back to factory length, and then some.
The spindle is precisely 1.250
Is drill rod a good choice for this? If so, what grade would be best as compromise between hardness, and machinability? If not drill rod, what should be used?
The factory spindle has a threaded insert in the back of the spindle, so I will only need to drill/bore the replacement to swap it over (no internal threading needed).
Thanks in advance for the advice.
