Citxmech
- Aug 23, 2018
- Seattle, WA
Hi,
I have a cast iron bushing block for an old American Tool Works lathe that I need to repair. The item has a chunk missing with the fracture going in between a bolt hole and a taper pin hole (See attached pic). I don't have the broken piece, unfortunately. My plan is to fill in the missing area with braze and remachine it as required. Drilling/counterboring the bolt hole should be pretty straight forward - but I'm a bit concerned about the taper pin hole. I can try brazing around an inserted pin covered in graphite, or just fill and redrill/ream the pin hole. About 270 degrees of the original pin grip area remains. My question is, if I drill and ream the taper pin hole, what flute type would be best considering the two metals?
Thanks!
Thanks!
