I have a 9x20 Central Machinery older lathe I have been using and trying to fix up. I have improved it quite a lot from the time I bought it through Craigslist, but I want to run an idea for this last bit of slop by all of you. So far I have managed to get the carriage and cross slide rock solid. I made a tool holder mounting block to use instead of the compound since I rarely do threading or tapers and don't need to put the wear and tear on it unnecessarily (never mind the slop it adds to the set up). Here's the problem...
I get about .003 movement from to back between the mount and the cross slide
and another .003 between the tool holder and the mount. The result is lots of chatter no matter what material I'm cutting or what tool or speed or tool height or coolant I use.
The tool holder is one of those lantern types.
My proposed solution is to mill the bottoms of the tool holder and the bottom of the mounting block leaving 3 landing pads each to stabilize their foundations. I will try this unless someone can show any reason that is would not be a good idea. Then (if I do) I will post the results in this thread.
