gregormarwick
- Feb 7, 2007
- Aberdeen, UK
135mm long turned part, 16mm h6 centre relieved bore, 4.985-5.015mm internal keyway straight through.
Keyway position is specified as a feature of symmetry with the bore diameter as the datum, and a tolerance of 0.0127mm. Depth tolerance is a bit more open at +/- 0.1mm
I don't know the purpose of the part, but knowing the end user, I suspect it is for sliding torque transmission inside a linear actuator of some description.
This is beyond our in house broaching facilities, so it will be subbed.
Question is, given the tight geometric tolerance, who should I sub it to? Would this be difficult to wire? Broachable?
