sputnikprecision
- Mar 21, 2007
- Malta- Europe
We are currently buying pre-cut POM round bar from 200mm to 120mm Diameter in slices of 18 or 30mm. We are being overcharged in weight plus the cutting charge. We do have a mechanical band saw which can handle as large as 300mm in our shop but I know cutting Derlin can be tricky as the blade can seize in the rod, apart from issues not going straight etc etc. Plastic may sound easy but it is not! We would need to cut hundreds every time so we need some sound advise not to get stuck.
Many thanks
Many thanks
