Scuffy
- Jan 13, 2007
- Shores of Lake Erie
As a quick disclaimer I did cross post this on a couple groups that hang around on FB in hopes that saturating every angle possible may yield more chances of finding folks that would have tidbits of info...
Despite not having much time lately I was finally able to get the Bijur check valves, compression fittings, 3/32 copper line and most components installed in the Fray mill. Before I button things up and get the table back in place I wanted to ask about the drive bushings. When replacing the other parts in the system I was able to easily pull the 3/32 line from the existing drive bushings. They didn't seen to act as compression fittings and most of them certainly weren't crimped onto the the tubing. Is this an indication of prior tampering or is the fit supposed to be a bit loose? The flange at either end of the saddle for the X axis screw has the lines coming in from the top and dripping down onto the screw. But the bushings dedicated to the ways come up from underneath. Those are the ones I question. If the copper tubing is loose then it would seem to me that nothing would prevent the way oil from making it's way back down, between the bushing and tubing, taking up residence in the saddle or puddling somewhere.
When I talked to the rep at Bijur about this she said she'd talk to her guy in "Applications". When I heard back from her all she could say was "Well there really isn't any information here on installing them. You just kinda tap them into place I guess." Nothing more.
So does anyone know what type of a fit I should be looking at when it comes to these bushings? If I can't rely on Bijur to tell me... I'm afraid this is one of those tidbits lost to time. Ugh.
And yes- I have some touch ups to do where some idiot spilled a bunch of acetone that didn't have a cap tight on it.... (Geeeee I wonder who that was?) Sure enough it loves to do what it was intended to do- dissolve all your hard work!
