Bizarre lathe vibration
Results 1 to 11 of 11
    Jun 2007
    Bath, UK
    27
    Default Bizarre lathe vibration
    I have a really strange vibration problem with my Bulgarian ZMM lathe. It's a great machine which I've used for over 18 years, however it has slowly developed a vibration in one gear. This is where it gets weird: If I reverse the motor (3 phase) and put the machine in reverse (so the spindle still rotates correctly) the machine is as smooth as silk! Really can't get my head around this, obviously I need to have a look in the headstock but finding time in my busy shop is a problem.
    Any ideas?
    Dec 2008
    New York
    10,309
    2670
    Quote Originally Posted by Tony McPhee View Post
    Any ideas?
    i had a lathe i had hand tapped a 1.5" 12tpi thread on and had lathe headstock locked. the force required damaged the pin in gear holding headstock from turning. using a 18" wrench on the tap was not a good ideal
    gears probably damaged
  3. Likes Tony McPhee liked this post
    Aug 2005
    Bay Area, CA
    97
    220
    18
    Booting off previous post -
    In your "reverse and reverse" configuration, is there a gear which is not used but which is used in the "forward and forward" arrangement? Might be a clue.
    Good luck,
    Monoblanco
    May 2017
    Massachusetts
    384
    413
    193
    I think Monoblanco nails it. The reverse tumbler has two gears. One drives while the other idles. If the only difference is the motor in reverse and the reverse tumbler in reverse, my guess would be a bad gear (or maybe just a chip caught in the gear that is idling in reverse).
  6. Likes Tony McPhee liked this post
  7. #5
    May 2002
    South Central PA
    13,828
    2401
    3643
    FWIW I had a W&S #3 that had a slightly twisted bed when I bought it. It also shook at one speed. I got the bed straight by twisting it straight by bolting it to the floor. After a few years the shake when away, and the bed no longer sprang back when unbolted from the floor. Makes no sense, but neither does yours. I can't say this has any relevance to your machine, but just maybe the leveling of your machine deserves a look after 18 years.
  8. Likes Tony McPhee liked this post
  9. #6
    Jun 2007
    Bath, UK
    27
    Quote Originally Posted by Dumpster_diving View Post
    Thanks guys, my guess is a damaged tooth as this speed gets used a lot. The lathe has a clutch for forward/reverse, not sure how reverse works as I haven't had the cover off the headstock for years. I suspect the driving flank of the teeth on the gear concerned must be worn as it only affects this one speed roughly in the middle of the range.
  10. #7
    Jun 2007
    Bath, UK
    27
    Quote Originally Posted by Mud View Post
    I moved the machine about 6 months ago and leveled it again, no change!
  11. #8
    Jan 2005
    Houston
    6,123
    707
    2854
    My old Colchester was 'smooth quiet' in high gear reverse. In high gear forward, it was smooth but noisier by a lot. I had the gearbox cover off, no broken teeth or anything else that looked bad. I always assumed it was 'the bearing' though it also looked good.
  12. #9
    Dec 2012
    AUSTRALIA
    2,830
    12
    913
    If the motor reverses though unit contactors ,check the forward contactors for burned contacts.,or maybe a problem in the contactor solenoid or coil.Sometimes they "growl"....Worn gears usually make a lot of noise before any vibration would be felt.....also check for a worn shaft /loose pulley /key/on the motor.
  13. #10
    Apr 2018
    3,973
    1794
    Quote Originally Posted by GregSY View Post
    Most likely tooth wear. They look fine but the shape has worn enough so that the teeth bang when they engage. Just a little bang but thousands of times a minute ...
  14. #11
    Mar 2006
    jacksonville,fl.
    1,252
    1087
    418
    If you take the head cover off and find helical gears in there maybe one in the train that set uses is changing its thrust direction when you swap things around.It may be rubbing one way and moving away from the interference the other.A loose shaft locking collar will let it float back and forth.
  15. Likes Hopefuldave liked this post
