When I need to replace a screw or bolt in something old and the currently available plated fasteners do not look right, I heat them red hot which burns the plating off and leaves them black. I can't say how durable a "finish" it is but it looks right. A quick soak in muriatic acid will dull them and eventually remove the plating and then you can use the tool black.
..... As others have said, plated fasteners cannot be blued. Blueing (or blacking) .....
heating the fastener to a red heat will soften the steel, and a quench will not reliably restore temper without a proper heat treat. generally a bad idea unless you are nowhere near the strength limits of the fastener.
If you are only doing a small batch, the blackener (I usually go with the Birchwood Casey products) will remove the zinc just fine. if you are doing some quantity, I would use a sodium bisufate "pickle" such as Spearex brand to strip off the zinc. safer to work with.
Down and dirty, I do it also, it leaves a durable finish. Just be sure to fully immerse the part in the oil, or you could have a fire.I have heated them and quenched them in used motor oil, turned them a nice black color.
yes, i need the strength (automotive application) and even more if they are sheet metal screws. i usually only need a few of a kind, so no way of buying them. my blackening solution (two different ones actually) does nothing to zink plated screws. so the only solution would be to strip them and blacken them, right? then they will rust fast.
Notice
