Blind Measurement of Casting Thickness for Drilling and Tapping - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Jan 2007
    wales.uk
    1,199
    134
    187
    Unconventional but I did have some success with a magnetic pull off test, elcometer was the brand, used for coating thickness but it definately stuck better to thicker ferrous substrate, it’s basically a magnet and spring thing, not neodymium! Just plain old iron, fairly weak
    I don’t understand the ultrasonic unless there’s a big lamination in the casting, there should be three spikes on screen if it is though I don’t know how good your head is, wallpaper paste makes a good contact media at a push.
    Mark
  2. #22
    Aug 2004
    Virginia
    2,468
    179
    980
    A couple of rare earth magnets should hold your display I would think. Possibly the scale as well if you use a few very small locating pins.
  3. #23
    Oct 2013
    Midwest
    63
    11
    20
    I appreciate all of the feedback thus far.
    So it sounds like the easy button options are gone.
    After some (very specific) searching, I found online where one vendor says my model of ultrasonic tester is not compatible with cast iron "due to its big crystalloid composition". I don't have access to a rental, although that would be nice. I did find another ultrasonic tester (SSEYL UM6500) that specifically lists cast iron (nodular cast iron, and gray cast iron). I will see if this works.
    Turning out to be some rather expensive holes...
    The tips you guys have provided may still come in handy if I can't find a spot thick enough to do a blind hole.
