Box turning tool on engine lathe
Results 1 to 11 of 11
    Jan 2007
    Central FL
    865
    6
    19
    Default Box turning tool on engine lathe
    Smart idea or not? I was planning on using these in my AXA boring bar holders.
    Feb 2006
    Indiana
    13,870
    797
    4636
    It is kind of tricky to line up a turret tool mounted to the compound slide exactly on the lathe centerline. Other than that issue, it will work fine.
    I have lever-operated tailstocks for my Hardinge and Clausing lathes and ER collet chucks on Morse taper shanks that can hold my 5/8", 3/4" and 1" shank turret tooling. These tailstocks are handy for using Miller Quick STR-type knurling tools and Geometric die heads for low volume jobs. The tailstocks would work with most any turret tool, but I tend to do plain end turning on the lathes with the slide rest and a turning tool instead of a box tool. I have turrets, but have not needed to set one up on a high volume job for many years.
    Larry
  3. Likes sfriedberg liked this post
    Virginia
    19,706
    7561
    11845
    Quote Originally Posted by madmachinst View Post
    Meahh.. AXA sets vert, topslide sets Hor. Doable. Might lose as much throughput as it gains?
    "Smart idea" means you have already ID'ed some advantage in the tool itself for a given tasking?
    AXA size sez your horse is in a range where you can find plenty of bed-turret systems.
    If you need that, do that, gain a lot of other turretish stuff, if not, not.
    See-also "gang" tooling if it might help earn coin faster..
    Jan 2007
    Norfolk, UK
    21,350
    16713
    17412
    Quote Originally Posted by L Vanice View Post
    Larry
    +another on what Larry said, .........over the years I've used one on a variety of 7 - 10'' lathes in my home shops (10'' Logan, 7'' Taiwanese Myford clone and 10'' Boxford (SB clone) ......and made plenty $ in the process
    If you can, get a roller box of the retracting type, much faster and no marking of the work. .....Tangiflow is the Brit one I know (but unfortunately have never owned)
    OH YES(almost forgot) - You wil almost certainly need a bed stop.
    Virginia
    19,706
    7561
    11845
    Quote Originally Posted by Limy Sami View Post
    May be too late to acquire a NEW Tangi-Flow ....unless someone has bought the line. Their website has gone dark.
    You-Tube still has their vids:
    Tangi Flow Roller Box 2015 1 - YouTube
    See also Boyar-Schulz.
    Boyar Schultz box tool with carbide insert conversion cutting 01 tool steel. - YouTube
    And Hardinge. Lots of used Hardinge goods on eBay. As usual.
    If not high-volume production or first need of many, hard to justify the costs.
    But DIY isn't rocket science. Just "different" from the boring usual.
    Or .... feeling lucky?
    Extended Small Diameter Turning -- No Problem - YouTube
    2,060
    383
    336
    OH YES(almost forgot) - You will almost certainly need a bed stop.
    Brock make a retracting type. The US agent was Wickman,now I don't know.
    Virginia
    19,706
    7561
    11845
    Quote Originally Posted by camscan View Post
    Some oddities turning-up:
    L & T Brock --->> Tangi-Flow Products --->|| ??? Current whereabouts unknown???
    One browser said that the website was "temporarily suspended"
    Another browse found an offer to sell (the website or <domain>.<tld>
    That said, Zoro UK and Cromwell carry Brock, in the present moment!
    Cromwell Tools - Experts in Hand Tools, Power Tools and PPE
    Could was the sales & marketing channels have simply withdrawn to work via distributor channels ... with little or no change to the holders (and inserts) themselves?
  9. #8
    Jan 2007
    Norfolk, UK
    21,350
    16713
    17412
    Tangi Flow are still there and in business.
    Just rang them and got sales and they are open for business etc etc - I was told there were ''problems with the web hosting company''
    FYI Tangi flow website (when it's working) Temporarily Disabled
  10. #9
    Virginia
    19,706
    7561
    11845
    The "usual suspects" of Unix tools turn up four players in the same loo stall at the moment.
    Probably in the midst of migrating to a new hosting provider and website toolset, but "whilst under duress" as-in unresolved dispute.
    Because anyone with HALF an ounce of experience does that seamlessly. Even WHEN there is a bun-fight afoot.
    It's why your registrar, nameservers, mail host, and web host are always placed with independent and separate entities.
    Control the FIRST two, you can choose the other two in about two seconds. Literally, not figuratively, first-most-aware, as much as three days, least-most-aware.
    "TTL" thing (Time To Live.. of a published DNS routing record).
    Proper "parallel cutover", all-hands cooperative, there is NO break in service at all. "Parallel" means exactly what it says it means.
    "While we wait..."
    https://www.wickman-group.com/wp-con...t_Under2MB.pdf
    Tangi- Flow = Tool manufacturer in Coventry, England
    Automatic House
    Discovery Way
    Binley
    Coventry CV3 2TD
    United Kingdom
    +44 24 7642 1200
  11. #10
    Oct 2005
    21,574
    I've done it on my Logan 9".
    However, the AXA is too small to hold the shank.
    I made a simple block toolholder, put a milling machine boring head
    in the chuck, and bore the block in place.
    Alignment is easy, simply bolt it down, and use a dial indicator
    on the block's flat surface.
  12. Likes Limy Sami liked this post
  13. #11
    Jan 2007
    wales.uk
    1,712
    347
    384
    I have used a roller box tool on an engine lathe several times, if you look at the tool it won’t take long to realise the forces generated are in fact less than say a right hand knife, setting them up is a bit trial and error, the cut is supported on the rollers so good if you have a worn machine, I dir have a 6,8,10,12 and 16 ready set, very lazy when you have them tuned, Chuck bar, slam the box on it, finished shaft, coupled with a die head making loads of odd bolts was easy, as correctly pointed out a bed stop ( mine was like the turret on a router, in fact I think it was once part of a cheap crappy router I cannibalised)
    Not nearly heavy enough really
    Mark
  14. Likes Limy Sami liked this post
