Flute Maker
Cast Iron
- Feb 17, 2007
- Needham, MA
to my eye it appears that you have two different parts meant for mounting on to different surfaces one flat and one on an incline . I can't see that either of the parts is bent. From the picture it appears to me that both parts are in the shape they left the factory
The lamp won't stand up the way it is. The only thing I thought of was screwing it down to a steel plate and heating it up with a torch, while leaning in it.
If it is bent, it will have work hardened. Do as Adama suggests and anneal it. Bolt it down to something sturdy and hit the round part with a rawhide or dead blow hammer to trY to avoid dents. If it moves, you may want to anneal it again when you get part way there. I would try this only if you have a foundry that could cast a new one from one of the good originals, as it may break.
Jim
What about keeping it hot, while rapping on it, after annealing?
Payson.
View attachment 186174View attachment 186169View attachment 186169View attachment 186169
Here's another picture. This ones from the bottom. You can see the twists in the metal.
No, don't. If you are bashing brass, do it at room temperature. If it gets stubborn, re-anneal it. Don't beat brass hot, as it's very likely to come apart on you.What about keeping it hot, while rapping on it, after annealing?
Notice
