andy_m
- Jul 13, 2015
- Bourne, Lincs
Hi,
i have a promblem with the knee lift on my Bridgeport, when winding the table up towards its maximum height, the crank handle is nearly impossible to turn, it gets progressively tighter
its get so tight i think i will break something
we had the knee gib out, that comes out easily and looks good
the auto way oiler is working fine, with nice clean oil on the dovetails
the brass columm lifter nut seems too tight and after lifting from the middle of its travel to where it gets tight the brass nut gets very hot, the nut does not have an oiler or grease nipple, and is fed with a pipe dropping oil on the side of the screw
i am convinced its not the gib or the ways and must be the screw as the nut runs freely from mid position to the bottom
we,ve jacked the knee up with a 15 ton machine jack with the pedestal unbolted and the knee glides up and down, so conclude the problem is with the screw / nut
has anyone else got any experiance of this problem
also just to say this is a metric machine made in the UK IN 1980's
i can source a new inch screw and nut, but am struggling to find a new metric screw and matching metric nut
one thought we had was that the screw is strectched and that effects just the bottom of the thread
has anyone the actual dimensions for the original metric screw ? we think it m32 x 5mm pitch left hand single start
or suggestions as to the cause
many thanks
Andy
many thanks
Andy
