Howie Dines
- Sep 17, 2020
- Germany (Formally UK)
Just finished measuring the 2x cams that I have, the Standard RH 2 Flute cam (2) and the RH Step Drill Cam (6)
Measured on a rotary table with cam rotating Clockwise when viewed from above. '0' angle is at the index pin.
10 Degree increments, dropping to 5 degree at the critical transitions.
Pictures of setup, cams and graphs of the plotted data below.
Best Regards,
Howie.
Cam 6 Cam 2
Angle mm Angle mm
0 14.08 0 11.51
10 14.23 10 11.76
20 14.35 20 12.16
30 14.5 30 12.54
40 14.63 40 12.90
50 14.75 50 13.26
60 14.87 60 13.60
70 15.01 70 13.94
80 15.17 80 14.27
90 15.30 90 14.66
100 15.40 100 15.03
110 15.52 110 15.43
120 15.65 120 15.83
130 15.86 130 16.26
140 16.04 140 16.66
150 16.21 150 17.05
160 16.45 160 17.43
165 16.50 170 17.77
170 16.49 180 18.02
175 16.40 190 18.06
180 16.20 195 17.99
185 15.89 200 17.87
190 15.41 205 17.74
195 14.74 210 17.59
200 13.87 220 17.26
205 13.08 230 16.93
210 12.45 240 16.55
215 11.92 250 16.16
220 11.53 260 15.72
225 11.38 270 15.23
230 11.42 280 14.72
235 11.53 290 14.15
240 11.65 300 13.51
250 11.91 310 12.89
260 12.17 320 12.36
270 12.43 330 11.83
280 12.66 335 11.63
290 12.88 340 11.5
300 13.10 345 11.43
310 13.29 350 11.41
320 13.48 355 11.43
330 13.65 360 11.51
340 13.81
350 13.93
Best Regards,
Howie.
Cam 6 Cam 2
Angle mm Angle mm
0 14.08 0 11.51
10 14.23 10 11.76
20 14.35 20 12.16
30 14.5 30 12.54
40 14.63 40 12.90
50 14.75 50 13.26
60 14.87 60 13.60
70 15.01 70 13.94
80 15.17 80 14.27
90 15.30 90 14.66
100 15.40 100 15.03
110 15.52 110 15.43
120 15.65 120 15.83
130 15.86 130 16.26
140 16.04 140 16.66
150 16.21 150 17.05
160 16.45 160 17.43
165 16.50 170 17.77
170 16.49 180 18.02
175 16.40 190 18.06
180 16.20 195 17.99
185 15.89 200 17.87
190 15.41 205 17.74
195 14.74 210 17.59
200 13.87 220 17.26
205 13.08 230 16.93
210 12.45 240 16.55
215 11.92 250 16.16
220 11.53 260 15.72
225 11.38 270 15.23
230 11.42 280 14.72
235 11.53 290 14.15
240 11.65 300 13.51
250 11.91 310 12.89
260 12.17 320 12.36
270 12.43 330 11.83
280 12.66 335 11.63
290 12.88 340 11.5
300 13.10 345 11.43
310 13.29 350 11.41
320 13.48 355 11.43
330 13.65 360 11.51
340 13.81
350 13.93
