Broaching puzzle
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Oct 2003
    Pinnacle, NC USA
    1,148
    1573
    49
    Default Broaching puzzle
    I attempted my first ever broaching today. Material was cast.
    Broach was DuMont 7/8" bushing C series. I used plenty of cutting oil. Dake arbor press. I even watched a video on YouTube. This was a two cut, I use the included shim.
    The broach was brand new and I thought maybe it was bent. Dead flatBroaching puzzle
    The piece goes on a raised panel router.
    Please notice the extreme differences on either end of this sprocket.
    I can't make crap up like this Broaching puzzleBroaching puzzleBroaching puzzleBroaching puzzle
    Happy New Year !!!
    Tom
    Sent from my SM-G960U1 using Tapatalk
    Nov 2017
    304
    185
    207
    Quote Originally Posted by TFPace View Post
    Happy New Year !!!
    Tom
    It happened to me and probably every apprentice I gave the job if he wasn't warned. This is why you always turn the part sideways so you can observe if the broach is angling off vertical and back off the pressure to make sure. The face angle of the tooth makes them want to dig in.
  3. Likes TFPace, Ray Behner liked this post
    Mar 2005
    Kansas
    7,614
    440
    3530
    Thats why you put a set screw over the keyway.
  5. Likes TFPace liked this post
  6. #4
    Mar 2006
    Wisconsin
    1,100
    14
    387
    Quote Originally Posted by MrWhoopee View Post
    Been there,done that. I didn't work for Mr. Whoopee, but like he said almost every apprentice has done it if not forewarned. Fortunately my (first) mistake was on a part that was easy to remake. It wasn't my only mistake, but like I said in a previous post "it isn't a mistake if you can fix it before the boss sees it".
  7. Likes TFPace liked this post
  8. #5
    Aug 2005
    Tucson AZ
    6,407
    9674
    3017
    You don't just push it through. Start in, back the press off and let the broach straighten up. Repeat. Don't try too much at once.
  9. Likes TFPace, Finegrain, digger doug, Rudd liked this post
  10. #6
    Nov 2017
    304
    185
    207
    Sometimes when the broach starts to dig in you have to turn the part over and start the broach from the opposite side.
  11. Likes TFPace, tdmidget, Mstcnc, Ray Behner liked this post
  12. #7
    Oct 2003
    Pinnacle, NC USA
    1,148
    1573
    49
    Thank you guys.
    When I flipped it over I was really disappointed. The front side is correct it's the rear that's awful.
  13. #8
    May 2002
    South Central PA
    13,656
    2303
    3559
    We routinely turn the part and bushing around so that the broach is facing toward the rear, toward the frame of the arbor press. Seems the ram wants to flex toward the front from the pressure of the pinion and the lower frame flexes downward helping the broach to tilt into the cut. Even on my Greenerd #6 press turning things around makes it go a lot better.
    Edit - Placing the broach at the rear of the ram also puts the force more in line with the rack teeth which reduces deflection.
  14. Likes TFPace liked this post
  15. #9
    Sep 2007
    Washington
    5,267
    201
    1593
    I have sometimes purposely angled the broach a little the other way (opposite direction from digging in) at first, and let the bushing bring it straight. But yes, push a little, back off, see how it's going/let the broach straighten out, then proceed.
    Regards.
    Mike
  16. Likes TFPace liked this post
  17. #10
    Nov 2003
    5,098
    180
    1586
    Well, here I am, that broaching apprentice. I never would have suspected.
    A great big thanks for the heads up.
    Now, if I can just remember that until my first broach job.
  18. Likes TFPace, Oilyneil liked this post
  19. #11
    Jul 2009
    S.W. PA
    241
    62
    59
    I respectfully submit that you all are wrong in this case. The part probably was supported on either side, maybe with parallels, perhaps even some distance on either side of the broach causing the part to tip forward under pressure. I've had this problem until I put the support directly in front of the broach insuring clearance for same.
    Bob....not the cat.
  20. Likes eKretz liked this post
  21. #12
    Mar 2005
    Northwest Indiana
    4,280
    911
    894
    In cases such as these I've occasionally made up a "dummy" sacrificial part to put under the thin one. That way the broach isn't cutting over such a narrow distance. The parallels probably contributed to the problem, as Bob noted, but this would probably have happened anyway with this broaching setup because the part is so thin - there needs to be a little more support and more teeth in contact at once if you want it to be trouble-free and easy. The tooth hook angle is what does it on these thin buggers.
  22. #13
    Oct 2003
    Pinnacle, NC USA
    1,148
    1573
    49
    Bob,
    Dake arbor press. Pretty straight forward. I lubed and relieved pressure multiple times.
    Thanks for your input.
    T
  23. #14
    Jun 2001
    St Louis
    18,074
    1923
    3059
    ekretz is onto something..... How thick is the part? The pic does not show, and I did not see a reference.
    You MUST have at least two teeth in contact at all times, which pretty much means the part needs to be three teeth thick, or you need a backup piece. But even that depth does not guarantee no issues, it is just a minimum. If the part is several more teeth thick, you probably will not have any issues.
    I asked about a similar thing years ago, and that was the takeaway.
  24. #15
    Oct 2003
    Pinnacle, NC USA
    1,148
    1573
    49
    Quote Originally Posted by JST View Post
    1.875"
  25. #16
    Mar 2005
    Northwest Indiana
    4,280
    911
    894
    Another trick I've occasionally found useful is to place a small piece of drill rod or other straight pin sideways on top of the broach (parallel with top of keyway) and as close as possible to the cutting edge side of the broach while broaching. This helps prevent any off-kilter pressure getting applied in case of slight misalignment.
  26. #17
    Mar 2012
    Geilenkirchen, Germany
    2,438
    1459
    1228
    This thread has made me laugh. Unfortunately, I made the same mistake when I broached my first keyway. I never had anyone to show me how it should be done, but I figured it out in short order.
  27. #18
    Jul 2009
    S.W. PA
    241
    62
    59
    Quote Originally Posted by steve-l View Post
    Sir,
    Please elucidate and enlighten us.
    Bob....not the cat et al.
  28. #19
    Mar 2005
    Northwest Indiana
    4,280
    911
    894
    I am pretty sure he's just looking back and laughing at the memory of when he had the exact same thing happen. Same as me.
  29. #20
    Jul 2009
    S.W. PA
    241
    62
    59
    Quote Originally Posted by eKretz View Post
    Yeah...I get that.
    Bob....not the cat.
