beckerkumm
Hot Rolled
- Aug 5, 2014
- Wisconsin Rapids WI
I need to make two keys for a clutch assembly. The keys engage the plates of a wet clutch that run in DTE light oil for a lathe. What type of bronze would work best? I need to turn and machine although I could finish off with a surface grinder if that is possible. Here are pictures. The parts are small, basically 1" x 1" x 5/16" diameter.. If more info is needed, let me know. thanks, Dave
