Budd wheel conical lug nut seat specs.
Results 1 to 16 of 16
    Aug 2004
    1,106
    8
    6
    Default Budd wheel conical lug nut seat specs.
    I'm looking for the conical lug nut seat countersink specifications and a tool for it. I can't find anything on the web.
    Edit!: Some info shows ball seat and some shows conical.....
    Anybody have any info. on this?
    Jul 2009
    Peoria, IL
    11,737
    51
    8991
    I suppose there is probably an SAE spec for it. You might try the local old folks home
  3. Likes moonlight machine, James H Clark liked this post
    Aug 2004
    1,106
    8
    6
    SAE - good idea. I just found one publication that might have it but they want $355 for it....
    I'm hoping for an alternative..
    There are millions of these all over the world every where. No specs on the WWW?
    Jul 2002
    Maryland
    4,440
    769
    648
    Have you tried the Tire & Rim Association? I have a copy of their 2001 Yearbook of specs if the spec you are looking for is found in that yearbook. I looked very quickly and didn't see it. But may not have been looking for the "right thing".
    The Tire and Rim Association, Inc.
    Aug 2004
    1,106
    8
    6
    Good idea but they want $125 for it. I looked for a used one on Amazon and ebay - no luck.
    Nov 2007
    marysville ohio
    9,615
    2762
    6400
    Quote Originally Posted by chevy43 View Post
    Just get one from a scrapyard, must be millions around yet.
    Jul 2009
    Peoria, IL
    11,737
    51
    8991
    There were at least 3 different sizes of Budd style nuts. The most common are 3/4-16 inside and 1-1/8-16 outside. Some are 15/16-12 inside and 1-5/16-12 outside. Then there is a metric version that is M20 inside M30 outside. I think they all use 13/16 or 21 mm square on the inner nut but the outer nut is 1-1/2 hex on the common one, 1-3/4 on the heavy one, and 1-5/8 or 41mm on the metric one.
    FWIW, I hate budd wheels. I used to work on rusty old Freuhoff trailers with budd wheels. The right side is left hand thread (or is it the other way around?). About every 10th outer nut one you try to take off will either spin in the rim and loosen the inner nut leaving the outer and inner nut stuck together in the outer rim, or even worse, it will push the stud back into the brake drum and leave you with the nuts captured on the outer rim.
    I have a special wrench that clips on the ID of the rim to drive the inner nuts through the outer nuts when they come off together. What a pain in the ass. And I can't count the number that I had to heat up or that stripped or that broke off the stud as soon as you touched the inner nut.
  9. Likes Mud, James H Clark, magneticanomaly liked this post
  10. #8
    Aug 2004
    1,106
    8
    6
    I'm looking for the seat taper info. I need to chamfer the seat. Nuts are easy to get.
    Left side left hand - right side right hand.
    I always lube the nuts and tighten the inner nut tighter than the outer.
    If the inner turns I use my gear wrench that holds the inner while loosening the outer. It's must have tool for old trucks. they can be bought on e-bay for less than $60. They will remove or break off anything by hand. You can by a 3/4 or 1" socket adapter for them as well.
    Lot's of problems are caused by idiots with 1 inch impact wrenches and no sense.
    Attached Thumbnails Attached Thumbnails ken-tool-military-surplus-truck-wheel-rim-tire-lug.jpg   lug-wrench.jpg
  11. Likes muckalee liked this post
  12. #9
    Aug 2004
    1,106
    8
    6
    Turns out it's a ball seat. There is very little seat to try and extrapolate the diameter of the ball shape. It's kind of like trying to get specifications for threads from going to the hardware store and measuring bolts. As a machinist I like to operate from specifications.
    Since there are hundreds of millions of them - I'm hoping someone here might know.
  13. #10
    Aug 2004
    1,106
    8
    6
    $10 paid by paypal to the first person who can come up with official specs posted or sent to me for Budd truck wheel ball seats.
  14. #11
    Jul 2009
    Peoria, IL
    11,737
    51
    8991
    Check page 52 of this document. The large budd has a spherical radius of 1-3/16. The more common smaller one is 7/8.
    https://www.accuridecorp.com/files/2...4-06-22-12.pdf
  15. Likes sfriedberg liked this post
  16. #12
    Aug 2004
    1,106
    8
    6
    I'm happy with that. Thanks! PM your email and I'll send you $10
    Now I need to make or find a tool to do it.
    T.
  17. #13
    Jul 2009
    Peoria, IL
    11,737
    51
    8991
    Nah. That's what the forum is for.
  18. Likes chevy43 liked this post
  19. #14
    Aug 2004
    1,106
    8
    6
    Quote Originally Posted by ewlsey View Post
    I said I would - so I will!
  20. #15
    Aug 2004
    1,106
    8
    6
    I can buy a ball bearing 1 3/4 for about $10. I think I can grind a cutter out of it for what I want to do. I have to drill it for a shank to grip it in the drill.
    Maybe grind a flat on it and drill it with a carbide bit?
  21. #16
    Aug 2004
    1,106
    8
    6
    I'll post some pictures of my cutter when I get it done......
