doug8cat
Titanium
- Jul 10, 2008
- Philadelphia
Hoping someone out there might have an idea about the following intermittent problem that reared its head yesterday.
I was taking a 1/16" cut in CI at 67 RPM with a feed of .015, finished the cut stopped the table and it immediately sounded like some chap dumped a hand full of gravel into a gear box. Jogged it couple of times; same heinous sound. Stopped grabbed a coffee, manual and a cigarette. The manual after a looking through proved utterly un helpful. Ordered a proper manual from the usual scumbags, should be in my mitts Tuesday or so. Then the OCD kicked in and I decided to have kick at the cat myself to see if I could glean some info so as not sound as dumb as I am. Found the following the gear rattl'in correlated with stable speed.
Tried the following:
Set the speed at 11 RPM no noise, continued upping the speed, got up to 54 rpm with no problems.
Any one had similar problems?
Any thoughts would be appreciated.
Also put in a call to Bourn and Koch who supports the Bullard line, never heard back so far.
One last fun fact the machine does the same running at 44 RPM more often than not (till now just never run 44.) IS the cancer spreading?
Cheers
Cheers
