Call yourself a machist? Cut a meshing pair of these.
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Dec 2000
    Bremerton WA USA
    10,718
    41
    4415
    Default Call yourself a machist? Cut a meshing pair of these.
    Here's a stupifying solution looking for a problem.
    Hyperboloidal Gears 3D Printed 75 Deg. Skewed Axis Animation and Assembly - Hyperboloid - YouTube
    Next step, helical hyperboloidal gears
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by Forrest Addy View Post
    Usta beee.. a Machinashitist....
    What I am NOW .. you radical agitating TEASE! ... is just one more jealous Old Fart a wishing and hungerin' I had me one of them 3-D printers he used ... (that part is EASY!) ...that could spit-out 4XXX pre-hard.. 8620.. or Nickel-Aluminium BRONZE!
    Which is NOT so easy.... YET!
    Especially when you get the same follow-on You Tube as I did!
    Photogrammetry!!!
    How to Copy (almost) Any Object - YouTube
    Keep 'em coming, Forrest!
    There is still more to life than "subtractive" masheenin' on fossilizing Old Iron!
    The Operators, if not also our machines..
    Jan 2007
    wales.uk
    1,351
    205
    246
    Suppose a cnc could do it, old school you’d be stuck with a gorton copy mill if you needed a copy, either way a challenge I’m sure
    Mark
    Jul 2013
    Indiana
    3,369
    4933
    1727
    Can't they do things like that on a multi axis wire, the gears part?
    Brent
    May 2002
    South Central PA
    14,230
    2635
    3961
    I didn't see operations to add internal threads for the small fasteners, were they printed right in the parts?
    Jun 2008
    59
    12
    22
    5 axis wire should do it
    Jul 2013
    Indiana
    3,369
    4933
    1727
    Quote Originally Posted by Mud View Post
    Yes, we are printing threads in toolsteel where I'm at. Shity looking threads but they buy them.
    Brent
  8. Likes Mud liked this post
  9. #8
    Jan 2013
    Louisville, KY
    3,181
    7668
    2732
    Couldn't the same be achieved with a set of 45* helix-angle gears? - That is, transfer power 90* off-axis?
  10. Likes Bobw liked this post
  11. #9
    Nov 2011
    Missouri, USA
    2,136
    1358
    2732
    A lot of times you can use a regular screw as a self-tapper, with the right pilot hole size. I've printed some threads into parts, but little stuff like that which requires very little torque to 'form tap' with the screw... I might just print it as a regular pilot hole. For stuff that matters, an embedded slot or hexagon for a captive nut is best.
  12. Likes Mud liked this post
  13. #10
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by Jashley73 View Post
    He is not at 90 degress here. Said it was what 75 degrees?
    Whatever the application NEEDS is the actual point.
    Historically, "universal solution" HAS BEEN to come in at right-angles, then rotate a second set of right-angle gears at any arbitrary angle 'round that output shaft. Works well, is all over the place for hundreds of years.
    But takes more space ... and two sets of gears, rather than but the one.
    3-D is one of the most USEFUL of game-changers since casting was expanded from holes in the ground and sand molds to precision metal dies and alloys that came out ready to use.
    It is also perhaps the fastest improving technology yet introduced since the Industrial Revolution began.
    Since the same CNC tools aready proven underpin it, it can also allow production at arbitrary distances from design, R&D, and testing.
    IF.. mankind can avoid obliterating ourselves long enough to reach out for the stars?
    3-D printing.. or something several steps yet BEYOND it.. will play a MAJOR role.
  14. Likes allloutmx liked this post
  15. #11
    May 2003
    5,208
    21
    589
    And you termite are the fastest deterioration of a human! As you call it "a rotted mind"!
  16. #12
    Jan 2013
    Louisville, KY
    3,181
    7668
    2732
    He not 90 degress here. it as waht 75 degrees/ Whateer the application NEEDs is the point.
    So let me ask it another way, in case the implied meaning wasn't clear enough previously... Couldn't the same be achieved with a set of [X / 2] helix-angle gears? - That is, transfer power [X] off-axis?
  17. Likes Mud, Bobw liked this post
  18. #13
    May 2002
    South Central PA
    14,230
    2635
    3961
    I can't see why not. Like bevel hypoid gears. That the axes are non-intersecting severely raises the degree of difficulty, might require a single purpose specialty gear cutting machine or wire as mentioned above.
  19. #14
    Apr 2018
    6,074
    2911
    Yes. You can cut bevels at any angle you want. And no one in their right mind would make gears with face widths like that. This guy mostly needs a big jar of KY jelly for his hand.
  20. #15
    Jan 2013
    Louisville, KY
    3,181
    7668
    2732
    Quote Originally Posted by EmanuelGoldstein View Post
  21. #16
    Sep 2018
    805
    1470
    373
    i dont see how this couldnt be cut on a 5 axis mill, am i missing something?
    prob not the most efficient way to do it, but for sure doable.
  22. #17
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by empwoer View Post
    As with Herringbone gears.. after long pondering over whether their intersection should be a sharp chevron or a complex curve, modern analysis proved a GAP is actually stronger and more enduring AS WELL AS easier to generate!
    Note the fine detail as his "demo" hourglass gears approach their least diameter?
    "Only because he COULD" Putting on airs, actually.
    No need to GO there at all. Lose nothing of importance if there is more "air", less material in there.
    Make the "real" power-transfer section simpler, faster, and easier to cut.
    Motor-vehicle offset hypoid differential gears are only a narrow "ring", after all. Not all that often they fail, is it?
  23. #18
    May 2019
    Michigan
    2,421
    1255
    1783
    Note that the question is about being a machist. He said nothing about machinists.
    I just thought I'd point that out for you...........
  24. Likes empwoer, Joe Miranda, fusker, Oldwrench liked this post
  25. #19
    Apr 2018
    6,074
    2911
    DMG does this at shows, 4 axis is enough. Sometimes 3. In fact it's kinda the new (ten years or so anyhow) thing for big parts, it's way slower than a big generator but much more versatile.
    But still would never make the face width like that.
  26. #20
    Virginia
    16,233
    7561
    10820
    Quote Originally Posted by ChipSplitter View Post
    So we should correct it? To what?
    "mock ass" seems to be what the guy with the spastic-plastic gears is getting the most of!
    Forrest is probably chuckling, either way! Cat amongst pigeons thing..
    You'd have to know Fold Arts and our sense of humour?
