camlock D1-5 spindle with 3J collets??
Results 1 to 20 of 20
    Sep 2019
    CANADA
    Manitoba
    8
    Default camlock D1-5 spindle with 3J collets??
    Hello
    First time posting on this forum. I know very little so forgive me if I ask stupidly obvious questions.
    I am wondering if there is a way to use collets that go up to 1.5" with my lathe. it has a cam lock D1-5 according to the manual.
    the research I've done says I need 3J collets probably? and a way to adapt to them. So I'm just looking for any advice on this.
    thanks.
    Jul 2004
    Houston, TX USA
    29,642
    Hardinge Sjogren 3J collet attachment with D1-5" back plate - 3J goes to 1 3/4 and collets were expensive when I last bought one over 20 years back
    Sep 2019
    CANADA
    Manitoba
    8
    so the 2J series collets would work also to get up to 1.5"?
    Jul 2004
    Houston, TX USA
    29,642
    Quote Originally Posted by JKCS View Post
    I'd have to look it up but I seem to recall 1 3/8" max
    Sep 2019
    CANADA
    Manitoba
    8
    thanks for the replies. is there a simpler/cheaper way then those hardinge Sjogren systems(I think they're called speed chucks?)
    I've seen on a smaller lathe it simply had a tapered insert that goes into the taper on the spindle, the inside of it then had a 5c collet taper, and there was a long round bar that went through the far side of the spindle and threaded onto the collets. is something like this possible for this scenario?
    Feb 2001
    Redwood City, CA USA
    4,961
    178
    902
    It is possible, but you would have to build it or have it built. The bar is a draw-tube.
    Oct 2005
    CANADA
    Ontario
    1,020
    196
    339
    I had that system on my Emco S11 until I got a Royal closer. The spindle taper is 1/2 MT5 so the adapter is 1/2 MT5 to 5C.
    The big question is what's the internal taper of your spindle? And is there an adapter to go to 3J?
    Jul 2006
    Australia (Hobart)
    3,551
    561
    2686
    Pratt Burnerd collet chuck. They go up to 1.5". I have one & use it a lot.
    Finding one with an integral D1-5 mount could be a problem. Finding one with a plain back you could fit to a D1-5 back plate would be easier.
    PDW
  9. Likes Limy Sami liked this post
  10. #9
    Oct 2006
    Norfolk, UK
    824
    813
    328
    Use to be you could get a key collet chuck by Crawford,to fit Camlock backplate. Don't know if they are still made.
  11. Likes Limy Sami liked this post
  12. #10
    Jul 2004
    Houston, TX USA
    29,642
    Any draw tube system "tube" has to be smaller than your thru hole in your spindle, and the system's capacity has to be smaller than the inside diameter of the draw tube - and smaller than the inside of the collet that has to screw into that tube
    Example: The 5C collet using South Bends have a 1 3/8 spindle bore, but the system's capacity for long stock is 1"
    "Big" collets have to have some sort of collet chuck - and are of course limited to somewhat less than spindle thru hole for long stock
  13. #11
    Sep 2019
    CANADA
    Manitoba
    8
    thanks guys for all the replies. with my internal spindle taper it seems to be too small to simply make a sleeve adapter for 3J collets. according to the manual here is what I have:
    Spindle Nose: CAMLOCK D1-5
    Spindle Through: Hole 1 5/8"
    Spindle Taper: 1 degree 29'15" (not sure what that means?)
    Taper reduction sleeve: MT-4 (I don't actually have a sleeve.)
    Spindle Dia at Front: 2.76" (measuring the front inner opening of the taper measures more like 1.88")
    So my options are to watch eBay for a SJOGREN speed chuck for 3J collets with a D1-5 attachment?
    Or Find one I can adapt to a D1-5 backplate?
    any other possibilities?
    thanks again.
  14. #12
    Jul 2004
    Houston, TX USA
    29,642
    The first says its near to .623" taper per foot on diameter - close to Morse taper
    The second says it is somewhere between #5 and #6 Morse taper
    In other words the sleeve had a standard #4 MT inside and a non standard Morse taper outside
    I bought my HS as a flat back - new - forty years ago - and one of the back plates I used with that flat back was D1-5"- long gone now
    So if you settle on HS, look for either a flat back or one already fixed up for D1-5"
  15. #13
    Oct 2005
    CANADA
    Ontario
    1,020
    196
    339
    Looks like your spindle is actually MT5: Machine taper - Wikipedia
    If so it's the same as my S11 and as far as I know the only adpter to fit in the spindle is MT5 to 5C and that would limit you to 1 1/8".
    Is the machine one of the unmentionables? ie: Big Green Bear, High Speed Aircraft, Active Bumblebee etc?
  16. #14
    Sep 2019
    CANADA
    Manitoba
    8
    Quote Originally Posted by johnoder View Post
    thanks for the info. I am not sure what you mean by "HS". do you mean one of the SJOGREN collet chucks?
  17. #15
    Sep 2019
    CANADA
    Manitoba
    8
    Quote Originally Posted by Terry Keeley View Post
    thanks. that may help me with future projects. I'm not sure what you mean by unmentionables? bad brands? its a ProtoTrak 1440 with lx2 control. old but a big step up for me!
  18. #16
    Sep 2019
    CANADA
    Manitoba
    8
    I was just looking at the different options:
    Hardinge HCAC Collet Chuck System Catalog 2011
    on page 23 it lists the D1-5 style with 3J collets, but under round capacity it shows only 1 3/8" and even the smaller ones like the D1-4 with 3J go up to 1 3/4"
    could this be a typo?
  19. #17
    Sep 2004
    Sonora , Calif
    574
    117
    121
    I have a plain back 3J speed chuck that I’l sell for $300. Plus shipping.
    Jim
    See reply #16 second page for dim.
  20. #18
    Jul 2004
    Houston, TX USA
    29,642
    Or other inattention to detail
  21. #19
    Oct 2005
    CANADA
    Ontario
    1,020
    196
    339
    Oh, no worries. Thought it might be a cheap import that can't be talked about here...
  22. #20
    Sep 2019
    CANADA
    Manitoba
    8
    Lol got it. I assume this is a decent quality one that I am allowed to mention?
  23. Likes Terry Keeley liked this post
