Can anyone help me figure out what kind of chuck taper is on this drill press?
Likes Likes:  0
Results 1 to 11 of 11
    Jun 2014
    Bay Area, CA, United States
    Default Can anyone help me figure out what kind of chuck taper is on this drill press?
    Hey All,
    I recently was given an old bench top drill press from my brother. It was one of two that he got from some old guys garage sale for $10. So, I thought I would scrub off the rust and repaint it and then just buy a cheap chuck (the one it come with is broken).
    It is a Central Machinery model: S-5901, made in China. The measurements for the spindle are:
    Larger diameter: 0.628"
    Smaller diameter: 0.579"
    Length: 1.025"
    Looking at the different taper dimensions this is closest to a Jacobs Taper #33. I bought a cheap JT33 chuck off amazon and thing won't seat fully on the spindle. It's like the taper angles don't match and it allows the chuck to wobble. Then when removing the chuck I can seen two shiny spots where it was mating with the spindle. Then I got my hands and a good name brand JT33 chuck and it was the same story. The original (broken) chuck fits on snug as bug, so I am at a loss of how to get a functional chuck for this DP, any suggestions?
    If you look at the pic of the data plate you'll see it says the spindle is a MT2, but that is a lie. When I took it apart to repaint it, the upper spindle is just a .400" straight shank pressed into some bearings. So, I'm wondering if this just a case of cheap chinese made junk, thanks for any help you guys can offer.
    Jon
    Jul 2004
    Houston, TX USA
    30,482
    Look here at the Jacob tapers and pick the one that matches your dimensions
    Standard Tapers
    Feb 2006
    Indiana
    13,020
    700
    3969
    There is a series of European DIN chuck tapers that are completely different from the American Jacobs tapers. I have a few Swiss and German chucks with DIN tapers and I bought an arbor for one from a China seller on eBay. DIN taper stuff is rare in the USA.
    That said, did you try a Jacobs 2 or 2 short taper? I think that is a popular size for your type of drill press and the 2MT might just be a translation mistake.
    Larry
    Nov 2008
    Chicago, IL
    1,548
    74
    141
    I wouldn't be surprised if it is a B16 taper -- I've made that mistake myself.
    Oct 2008
    Brenham, Texas
    1,132
    1092
    459
    Someone once told me you could stick a blob of play dough up inside the taper to model it.
    V
    May 2012
    Indiana
    1,008
    182
    360
    I had one of those years ago. There were two pallets of them at a local big box hardware store for something like $100. They sold a few then no more. Sat there for two months dropping the price. Then one weekend all gone. About a month later I stopped in at a local discount tool store, one with even lower quality than HF. Wada ya know, 1 3/4 pallets of drill pressed. By that time price was $20 so I got one.
    Runout with a 1/4" bit was 3/8"+. Ill bet that is the reason for the chuck change. Anyway the taper was unknown to me so I took out the spindal and cut a Jacobs taper. The metal turned like soft brass. Runout was fine after that..........but still a junky drill press.
    Bet the original paint color was metallic green. Nice blue paint job though.
    Dec 2010
    WA, USA
    1,505
    2062
    1040
    Quote Originally Posted by pritchaj View Post
    snip
    If you look at the pic of the data plate you'll see it says the spindle is a MT2, but that is a lie. When I took it apart to repaint it, the upper spindle is just a .400" straight shank pressed into some bearings. So, I'm wondering if this just a case of cheap chinese made junk, thanks for any help you guys can offer. snip
    Jon,
    Based on your nubie state and the machine you're asking about, I'm assuming you're not very familiar with machinery.
    Soo . . .Are you sure that the taper shown in your pictures isn't one end of a M2 shank? In other words, is that taper on a removable shank which is installed into your Morse 2 spindle?
    If it is as I suggest, you should see two 'knock out slots' when your quill is fully extended. If so, get a #2 Morse Taper Drift and knock the shank out of the quill.
    Get yourself a new (to you) chuck and an appropriate #2 Morse taper shank.
    Aug 2004
    Westwood, NJ
    748
    323
    378
    The original chuck should have the taper marked on it. B16 taper? here's a link to hf's newer model dp.
    http://manuals.harborfreight.com/man...0999/60238.pdf
    Jun 2014
    Quote Originally Posted by Arthur.Marks View Post
    You are correct Arthur, it is B16. When I looked up taper dimensions I got a list that only included Jacobs, Morse, Jarno, and Brown & Sharpes so I figured those were the only major types (what's that rule about assuming things?). I never had seen a mention of a "B" type taper. Now looking at the rusted over original chuck there is a very small B16 engraved right after where it says the chuck's min/max capacity.
    Quote Originally Posted by mach2 View Post
    You, Sir, are correct on the green color. It definitely seems very cheaply made, but it's better than what I had before.
    Quote Originally Posted by extropic View Post
    Jon,
    There is no doubt that I'm a noob, but I am familiar with Morse tapers and I did take the whole thing apart to clean it up. There is the taper that you can see in the pictures then it is just a .400" shaft about 6" long going straight up from that. At the top and bottom of the shaft there are 2" bearings pressed on that fit inside the quill. And the quill has no knock-out slots like you would see for a morse taper. What you described is what I was expecting it to be (seeing as that is what it says on the data plate) and I thought it would be a quick and easy fix. Here's a picture of the whole shaft with one of those bearings on it.
    Quote Originally Posted by egpace View Post
    You are right as well, it is small rusted over and I was unaware of there being a "B" type of taper.
    Thanks everyone for the input and helping a new guy who is still trying to distinguish his ass from his elbow in all things machinery.
    Jon
    Aug 2011
    Florida
    101
    12
    16
    That's a GREAT idea, if you have access to, and experience with a lathe. In fact, it's the BEST idea.
    Ebay has, now, an endless supply of B16 chucks. That would be the easiest way. Pay your $20 and wait two months for it to show up from China.
    Since you have already invested in Jacobs chucks, if you have a lathe, go for creating the JT33 taper.
  11. #11
    Aug 2006
    Virginia
    610
    862
    353
    5 year old thread...
    Joe
