Can anyone recommend source for miniature, (2-56), threaded dowel pin?
Results 1 to 7 of 7
    May 2006
    Illinois
    273
    104
    56
    Default Can anyone recommend source for miniature, (2-56), threaded dowel pin?
    Looking for a US-based source for small threaded dowel pins. Ideal would be a 3/32 pin, OAL 0.625 which would include ~0.125 of the end threaded to 2-56 and the opposite end slotted.
    Worst case I could buy shouldered screws from McMaster and turn the head down but they want $3.00-$4.00 each which seems high to me, not to mention the machining time.
    Quantities at this time are only 25-50'ish.
    Thanks.
    gm
    Jan 2019
    Hawaii
    737
    324
    205
    I don't think you can call it a dowel pin once the threads are on it. Maybe call it a threaded indexing pin or a threaded locating pin will help the search
    is this the kind of thing you are after?
    May 2006
    Illinois
    273
    104
    56
    Quote Originally Posted by Kevin T View Post
    Yes Kevin, that's exactly what I'm looking for. Thank you.
    I've tried searching for that and I'm having trouble finding one "off-the-shelf". My guess is that it will have to be custom given the small size.
    gm
    Nov 2014
    Florida
    5,689
    2252
    2829
    Shoulder screws (by default) are not nearly as precise in size as a dowel pin. Even looking at "precision" shoulder screws/bolts from McMaster the dia tol is listed at _.001/+0. Does that still work for your application?
    I am thinking you will either need to have them custom machined, or 'settle' for a shoulder screw and turn the head off. I agree though, $4 each for 50 parts PLUS the labor kind of stings.
    May 2006
    Illinois
    273
    104
    56
    Yeah... The tolerance is not an issue. I found another company that has a much better price: Socket Head Shoulder Screw | Hex Head Shoulder Screw. Worst case I turn the head down myself but I plan to check with them next week to see what the cost would be if they turn it off for me.
    Thanks.
  6. Likes Mike1974 liked this post
    Nov 2010
    UNITED KINGDOM
    990
    197
    243
    They are very like the threaded pin on the backgear ring on top of a Bridgeport mill.
    Try a search for Slotted Set Screw Partially Thread.
    Something may come up.
    Slotted Set Screw, Partial Thread | Metric Screw & Tool
    Buy Slotted Head Part Threaded Set / Grub Screws | 500,000+ Components | Accu(R)
    Nov 2010
    UNITED KINGDOM
    990
    197
    243
