philztheone
- Dec 28, 2019
Can I leave the jammed woodruff key in place or do I need to remove it?
My woodruff key is jammed into place (see photo), can I leave it as is(It took some doing to finally pry the crankshaft off.)? Do I need to remove this key(Had a go at it with a needle-nose pliers which didn't work.)?
Don't know if this relevant but it's a 1997 Accord DX straight stock as far as I know. It has an F22B2 engine. 2.2L, SOHC.
Thank you.
Thank you.
