They both use worms to rotate in precise increments. The difference is in the details as each is set up to be better for different tasks. But, yes you can divide on a RT. Many, dare I say all of them, can be fitted with dividing plates. Or you can just find the angular positions and go to each of them in turn. That may be more prone to error than using plates and an arm with a pin, but it does work. I have done it.
Is the size of a RT really in the way. Well, perhaps, but I have never been unable to work with it and I have a 10", which is BIG. And heavy! I dropped it once. Big ding in the floor, no noticeable damage to the RT. It is BIG and MASSIVE. And probably a lot more accurate than most dividing heads.
And you can probably do small RT jobs with a dividing head.
PS: If your RT did not come with dividing plates and none are available, you can make a set using the table itself. I previously posted this elsewhere, so I am quoting myself;
You CAN make a set of circles on your own, using ONLY the dividing head or rotary table you already have. They WILL be just as accurate as your worm gear is, with a small bit of random error due to the uncertainties of the machining process. I have described this process several times and you can search this site (
Activity Stream - The Home Shop Machinist & Machinist's Workshop Magazine's BBS) for these lengthy explanations, but here are the short strokes:
As someone stated above, a second generation plate made with YOUR existing head will be 30 (or 40 or 90) times more accurate than the first generation plate used to make it. The worm gear acts as a "precision amplifier". So if you have a one degree error in a first generation plate, the second generation plate will have only a 2 minute (1/30 of one degree) error. And when you use that second generation plate, the error on your work will be only 1/30 of that or 4 seconds of arc. I will guarantee you that your worm is not that accurate and no further precision is needed.
So to generate a new plate with any number of holes:
1. Make a first generation plate using any layout technique that you want. Literally ANY technique: the accuracy DOES NOT MATTER. If you can get the holes within 2 or 3 degrees of the correct positions that is 100% good enough. You do not even have to drill these holes, simple pencil marks on a paper disk and a pointer on the shaft will work. And by "will work" I mean that it will provide the accuracy I have stated above on a third generation plate.
2. Use that first generation plate to drill a second generation plate.
That's it, you are done and your work with this second generation plate will, WHEN USED ON YOUR HEAD, will be the third generation and will be at the accuracy that I stated above (4 seconds of arc or better plus the error in your worm). Thus you have made one "paper plate", the first generation and a second generation metal one.
One small note. The second generation plate made above is not at the high level of accuracy I claimed above BUT it will provide that level of accuracy when used on your head. If you want a highly accurate plate for direct use instead of one to be used on your head, then you would need to make a third generation plate to get that accuracy.
This is not magic, it is simple math.
MATH ROCKS!
