mr coffee
- Dec 4, 2008
- Burlington, NC
I an a noob hobbyist running an old bridgeport-style milling machine with a chinese face mill that is made for 5 size 433 square carbide inserts without a hole in them.
I've already used up all four corners of the inserts that came with it. I saw some 533 (5/8" IC) for cheap and wondered if I couldn't use them in my 45 degree facemill. Yeah, I know it would have a a lot less metal behind the cutting edge, but at low rates of feed, they wouldn't just break off, would they? I'm not in a hurry, but I should mention I am machining small pieces of 304 stainless, not aluminum or brass.
Sorry if this question is stupid, but I don't know what I am doing and deciphering the insert code for surplus inserts is pretty challenging, even with the charts I have found, and I can't afford to break PRICY inserts as I learn. "Surface finish" is something I do with sandpaper much of the time. <grin>
Thanks for any help. I'm braced for ridicule if necessary.
