Can a lathe be fabricated from mild steel ?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 84
    Aug 2018
    UNITED KINGDOM
    6
    Default Can a lathe be fabricated from mild steel ?
    Been looking at some YouTube efforts at building a lathe which range from junk to not so much junk. I'm pondering if there is any way to really build a serious small lathe that would equal a shop bought one ?
    Some of the basics you can't do without ?
    1. a high mass of stable cast iron to dampen vibration
    2. Excellent bearings
    3. Hardened and ground ( scraped ) bedways.
    I'm a welder and even if I fabricated a lathe from heavy sections and plates the distortion and stress in the finished product would be huge. I'd probably go find a scrap cast iron lathe bed and get it re ground , then start from a stable base.
    May 2009
    Canandaigua, NY, USA
    2,899
    142
    1293
    It's all design and execution. Heck, I could build a nice lathe from maple and some steel plates. Good lathes have been made from heavy round rod stock. SBs use simple plain bearings yet achieve excellent results. In the past people have made good lathes from cast bronze. OTOH, why not just find a good used lathe?
    Dec 2016
    Arizona
    163
    27
    56
    Quote Originally Posted by Waterworks View Post
    I'd probably go find a scrap cast iron lathe bed and get it re ground.
    At which point you would probably be into it for almost as much time/money as finding a good enough used lathe.
    If I needed a large wood lathe I might consider building something like a Oneway, and I would like to build a spinning lathe at some point. For a metal lathe though I wouldn't bother unless the whole purpose is just the fun of the project.
  4. Likes mike 44 liked this post
    Nov 2009
    Massachusetts
    387
    130
    One technical reason that cast iron is used for machine tool frames is that cast iron heavily damps vibration, thus controlling chatter. Making a lathe frame out of even the best of steel is likely to disappoint. There have been many attempts.
    The sourcebook for this is "Precision Machine Design" by MIT Professor Alex Slocum. This is a book by Slocum plus a course taught by Slocum and others.
    Available online: Precision Machine Design | Mechanical Engineering | MIT OpenCourseWare
  6. Likes steve-l, Spartan094, Yan Wo, PmGRacer, NC Rick liked this post
  7. #5
    Dec 2008
    New York
    10,234
    2656
    it will cost you more money and alot of time to make a lathe. easier and cheaper to buy one new or used. many used ones available usually biggest problem is how to deliver it as even small ones are heavy
    and engineering design to make a compact well engineered design is very time consuming. sure big clunky awkward design can be made. you could spend years and decades redesigning rebuilding for better engineered design
    Gingery lathe doesnt have to made from aluminum castings, can easily use steel.
  8. Likes gustafson, tim9lives liked this post
  9. #6
    May 2009
    2,899
    142
    1293
    You might try a search for "bar bed lathe". A few rather nice ones have been made.
  10. Likes Limy Sami liked this post
  11. #7
    Nov 2014
    Colorado
    2,971
    3488
    821
    There are ultra precision lathes built on a massive slab of granite (synthetic) - Tilted and un-tilted + use of air bearing spindles or Hydrostatic bearings depending on what you are cutting + size of parts.
    For optical applications the base is pneumatically floating / vibration damped / isolated. So theoretically you could weld together a base / box to support a granite block and slab based machine.
  12. #8
    Mar 2005
    Kansas
    7,626
    440
    3533
    You could buy the size lathe you want, brand new, for a small fraction of what you would spend building your own. With a store bought lathe you have resale value as well.
    If you wish to research the venture, I suggest you start with the book "Design of Weldments" by Blodgett, published by the James F. Lincoln Are Welding Foundation. There are several other books from the foundation that would also be beneficial, but that one is the most applicable.
  13. Likes Chuck Evans liked this post
  14. #9
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,294
    1200
    709
    Yes, you can build a lathe out of scrap steel if you have the desire to try, but as others have mentioned, it is not a cost effective way to get a lathe, and unless you do a spectacular job, resale is questionable. I believe it was WWI where we needed to tool up quickly, they poured lathes with a concrete bed and just used steel in critical locations like ways and spindles.
  15. Likes TDegenhart, avrprecision liked this post
  16. #10
    Jan 2005
    Houston
    5,749
    549
    2545
    What is it with people wanting to build their own lathes? This seems to come up way too often....I don't hear about people wanting to make their own washing machines or screwdrivers or weed eaters.
  17. #11
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,374
    2852
    5648
    Quote Originally Posted by GregSY View Post
    The fact they are even thinking about it impresses their girlfriend.... better to ponder making one's own rocket ship to the moon ...
  18. #12
    Oct 2007
    SPAIN
    3,647
    2070
    1348
    Cincinati made a mill of welded construction.
    Or was that Fadal?
    It was a line, and another line was a cast base.
    I've been pondering it to build a cnc
    But prolly go for a boxford headstock and saddle and bed cus that's all that would be needed.
    We'll see...
  19. #13
    Apr 2009
    NC, USA
    59
    11
    26
    Because "I tried to build a lathe once" sounds better than "I bought a used lathe and couldn't get it working".
  20. #14
    Jun 2008
    Burbank, CA
    331
    83
    58
    To answer the original question, yes a lathe can be made from weldments.
    I am quoting a long ago post from JimK here.
    "In 1958 Axelson was owned by US Industries, Clearing Division. The Clearing-Axleson lathes of that time had welded steel beds. The lathes were modern looking with squared off design resembling Lodge and Shipley's Powerturn machines.
    One advertizement in Machinery Magazine that year showed a Clearing-Axleson lathe taking a heavy cut on a work piece with an overhead crane holding the tailstock end of the lathe two feet off the ground!"
    Blodgett's "Design of Weldments" describes the design of a lathe from steel weldments.
    I wish I could test drive one of those Axelson welded lathes.
    Chuck
    Burbank, CA
  21. Likes digger doug, 4GSR liked this post
  22. #15
    Feb 2011
    1,294
    1200
    709
    Probably the high cost of small machines, and a lack of understanding of what all makes a true lathe. If you are willing to forgo feeds, threading capabilities and any real precision, a chunk of I-beam, some pillow block bearings, and a scabbed up carriage, is better than no lathe at all. I've seen a few in out of the way places where nothing else was available, but in the modern civilized world where a real lathe can be purchased cheap, why bother.
  23. #16
    May 2009
    2,899
    142
    1293
    Well, I've made screwdrivers on occasion.
  24. Likes M.B. Naegle, TheOldCar, tdmidget liked this post
  25. #17
    Oct 2005
    16,044
    … or so you think...take the blinders off.
  26. #18
    Oct 2005
    16,044
    Some Very large lathes were made in Erie Pa by "RD&D" and they used welded beds.
    One technique they used was to fill the fabricated bed with concrete (I was told
    by someone that worked there)
    IIRC the Morton Thiokol solid rocket booster lathe was one.
  27. #19
    Jul 2004
    Houston, TX USA
    30,253
    Not quite a lathe, but quite a lot of "fabbing up" in that 120 foot length
    Thirty-five years ago in Houston
    Attached Thumbnails Attached Thumbnails spiral-mill-01.jpg   spiral-mill-02.jpg   spiral-mill-03.jpg   spiral-mill-10.jpg   spiral-mill-11.jpg
  28. Likes 4GSR, PmGRacer liked this post
  29. #20
    May 2017
    Minnesota
    1,127
    1400
    772
    "To dampen" = to make slightly wet.
    "To damp" = to absorb oscillation.
  30. Likes karl, LKeithR, Mcgyver liked this post
