Carbide countersink speeds and feeds
Results 1 to 17 of 17
    Aug 2019
    10
    Default Carbide countersink speeds and feeds
    I have got some parts that have two holes laser cut to 1/2". I need to put a 5/8" countersink on the holes.
    I am running a 3/4" carbide 90° countersink, on a bridgeport clone.
    How fast should I run the countersink ?
    Jul 2006
    Hillsboro, New Hampshire
    12,668
    2891
    8775
    It comes down to stiffness of the setup in my mind. If you're holding the parts loosely (be careful!) then run very slow and watch your fingers. If you're fixturing the parts so they can't move and have a short overhang tooling setup, you can go faster.
    So (roughly) back gear lowest speed on a BP for the first, perhaps second or third from slowest with a well fixtured, stiff setup.
    Especially if using single flute, don't "bounce" the cutter into the work, bring it in slowly and smoothly so the cutting edge can engage without being damaged. Multi-flute tools are more tolerant of rough handling, but not by a lot.
    Jul 2006
    Cumberland, Maine
    530
    89
    129
    Quote Originally Posted by Norman.paz13 View Post
    What kind of wood are you trying to cut? It really does matter.
    Jul 2006
    12,668
    2891
    8775
    Quote Originally Posted by JohnMartin View Post
    ??? He does say "laser cut", which infers a steel or related material.
    Aug 2019
    10
    sorry forgot to say. the material is 1/2" A36 steel.
    Aug 2019
    10
    The part will be clamped in a vise. It is a 6 flute countersink
    The last time I tried this I was running about 300 RPM.
    I got about 140 holes, then the countersink got dull, had to send out to resharpen.
    I don't know if that's the expected life of the cutting edges or I was doing something wrong. (running too slow or too fast)
    I am hoovering the countersink above the hole, and letting the quill feed lower it and engage the work at lowest setting .0015" per rev.
    Nov 2014
    Florida
    6,185
    2451
    3075
    I think the feed is too slow. Also, the "crust" from the laser may be affecting your tool life.
  8. Likes AARONT liked this post
  9. #8
    Feb 2013
    Madison, WI
    1,240
    1286
    803
    I would be trying about .008"/rev. I've never had much luck feeding those multiflute carbide csinks slow.
  10. #9
    Aug 2019
    10
    I have had this argument with everyone in my shop. I know A36 can't be heat treated.
    But any laser cut edge, tears up cutting tools like crazy. I'm currently doing research on what affect the heat and CO2 gas has on the edge of laser cut parts.
    I will try increasing the feed.
    Thank you.
  11. #10
    Aug 2019
    10
    Quote Originally Posted by AARONT View Post
    I will try the max feed .006"/rev.
    Thank you sir.
  12. #11
    Jan 2005
    Victoria, Texas, USA
    4,600
    3110
    1254
    The carbon from CO2 will aid in hardening the surface with the plasma current. We used to run plasma cutter with nitrogen gas, the nitrogen would harden the surface glass hard. It's just a couple of thousandths thick but enough to tear up tooling.
  13. #12
    Jun 2009
    Michigan, USA
    2,923
    3421
    2227
    Why are you using the quill feed. You will get a better feel for what is happening with your chamfer if you hand feed it. Also, from my experience using carbide tooling in a Bridgeport type machine you will have more problems with chatter wrecking your tooling than wearing them out.
  14. #13
    Aug 2019
    10
    Quote Originally Posted by Big B View Post
    Tried using a HSS countersink, it countersunk 3 holes, and stop cutting just rubbing. Bought a new 6 flute HSS countersink and the same thing happened, about 3 or 4 parts before stop cutting just rubbing. I was goin about 500 rpm.
    Tried the same two countersinks on a scrap piece of A36 with a drilled hole, not laser cut, and they worked fine.
    I was using the quill feed, because I thought having consent pressure from the machine would give a better result on finish. i will try using just the quill.
    thank you.
  15. #14
    Aug 2019
    10
    Quote Originally Posted by 4GSR View Post
    Thanks for the info. Very interesting, and good to know.
  16. #15
    Jan 2019
    SWEDEN
    208
    65
    26
    Run 2000 RPM F.08 and if it sounds bad decrease the RPM. Correct RPM for that tool is around 1k-2k with that radius engagement in mild steel. G82 cycle with 10 rotations dwell for best result.
  17. #16
    Feb 2014
    FL
    4,194
    13436
    5001
    Quote Originally Posted by Tichy View Post
    "Quill feed"....
  18. Likes digger doug liked this post
  19. #17
    Jul 2006
    12,668
    2891
    8775
    Quote Originally Posted by TeachMePlease View Post
    "Quill feed"....
    Before manual machining I've started programming the operation, then printing the G-code out and eating it.
    Since I've been doing that, I can hand-mill elipses and 3D features within a micron.
    Hint: Print to paper, not Mylar. That was a mistake...
  20. Likes kenton liked this post
