CC
- Mar 14, 2006
- NW Pennsylvania
I have a CARBOLOY BBA-6 Bar with a BTA6 Head and a BBA-7 bar with a BTA173 head.
They both take triangle inserts, a shim and a lock screw.
TNMG322 insert with NL-34L screw and a 323 shim will fit the BBA-7 perfectly.
But the insert and shim will not fit into the BBA-6 bar and allow the screw to thread into the pocket.
There doesn't seem to be any damage to the seat. It looks perfect but there definitely is less clearance between the lock screw and
the edge of the pocket on the BBA-6 bar.
Can someone tell me if the heads actually take different part numbers?
It seems like the insert and shim need to be just a beat smaller....
And if someone has a sheet showing what parts are supposed to be used in those CARBOLOY BBA style units, I sure would appreciate a copy.
Thank you!
Chuck
Thank you!
Chuck
