carrol jamison lathe
Results 1 to 20 of 20
    Oct 2014
    Utah
    76
    13
    8
    Default carrol jamison lathe
    I just bought a carrcol jamison lathe, I cant find a model number on it. but the serial number is 993. from what i read that means its a pretty early lathe. I will post pics shortly. I was wondering if due to the early serial number if there is some place that people have accumulated serial numbers and know who or where the oldest one known to exist is.
    Virginia
    26,787
    7561
    8377
    Quote Originally Posted by shawnshop View Post
    They were not top-end lathes, nor ever developed the populist tribe of fans as South Bend did. Higher than average percentage have most probably been smelted over time, so you'll be fortunate to find even a dozen or two other minders of them in the present day.
    Not a slam - just the way it worked out in a once crowded and fiercely competitive marketplace.
    Bill
    Oct 2014
    Utah
    76
    13
    8
    I just bought a carrol jamison lathe, I cant find a model number on it. but the serial number is 993. from what i read that means its a pretty early lathe. I will post pics shortly. I was wondering if due to the early serial number if there is some place that people have accumulated serial numbers and know who or where the oldest one known to exist is.
    Sent from my KYOCERA-E6820 using Tapatalk
    Oct 2014
    Utah
    76
    13
    8
    So after a couple years I am finally getting to work on this lathe again. It didn't have a motor when I bought it. Which is part of why I got it so cheap. I am just trying to decide if I should go with a VFD or not and what HP and RPM motor to go with.
    Any one have any ideas what I should go with?
    Mar 2014
    Michigan
    456
    85
    245
    Go with a camera and post some pictures!
  6. Likes JRIowa liked this post
    Mar 2009
    Brunswick Oh USA
    4,514
    5011
    2687
    Need to know lathe size to tell you motor size. Pics please
    Oct 2014
    Utah
    76
    13
    8
    Quote Originally Posted by Ray Behner View Post
    Here are some pictures. It's tucked in behind some stuff so they are not the best I assume it to be about 13 ish by 40 swing
  9. #8
    Sep 2016
    Missouri
    781
    668
    221
    Edit. (At least a 1 h.p)
    I couldn't edit previous post on my phone.
  10. #9
    Sep 2016
    Missouri
    781
    668
    221
    South Bend Lathe Works - Publication Reprints | VintageMachinery.org
    You need r.p.m and pully size to get correct speed and torque.
    Go to link and find a similar sized South Bend to compare to and get motor size.
    The south bend forum guys here on P.M. may have more information
  11. #10
    Sep 2016
    Missouri
    781
    668
    221
  12. #11
    Oct 2014
    Utah
    76
    13
    8
    As near as I can tell this is the closest I can see but none of them have a motor mounted like want mine has (I am sure it was retrofit at some point)
    However this picture only shows 3 options for belt placement and mine has 4.
  13. #12
    Oct 2002
    Florida
    1,180
    122
    268
    At age 14 I was working as a grease monkey in an automotive repair shop, and had graduated to working on small engines. I had watched the garage owner turn armatures on his Carrol Jamison lathe. While the owner was gone, I needed a simple brass bushing. I switched on the lathe, drilled the bushing bore, turned the outside, and cut it off. When he returned, he asked where I got the bushing. When I told him I made it on the lathe, he simply shook his head and walked away. His companion later told me that she had expected an explosion from him, as the lathe was his personal turf. That incident was near the beginning of a long and successful mechanical career. The lathe looked just like the one shown in the thread. It had an overhead flat belt drive with a wooden lever that one reached up to clutch the drive in and out.
  14. Likes shawnshop liked this post
  15. #13
    Sep 2016
    Missouri
    781
    668
    221
    If you measured your lathe and measured at 14 inch for the swing it may be the 13 inch swing lathe .
    The 14 inch pictured has An actual swing of 15.5 inches.
    The 13 inch lathes on vintage machinery has 4 step pully. That may be what your lathe is. 13 inch with 14 inches of actual clearance.
  16. #14
    Oct 2014
    Utah
    76
    13
    8
    Quote Originally Posted by mllud22 View Post
    Ok that makes sense. As you could see from the pictures my measurements were crude since I was in a bit of a hurry. I looked at all of the pictures in the link that was posted and didn't see what you describe. Can you please post that particular pic/link?
  17. #15
    Sep 2016
    Missouri
    781
    668
    221
  18. #16
    Sep 2016
    Missouri
    781
    668
    221
    Wrong link.
    I went to the vintage machinery link I posted earlier and downloaded the 14"pfd and it also shows a 4 step pulley.
    Thanks to the guys that share these files.
  19. #17
    Oct 2014
    Utah
    76
    13
    8
    Wrong link.
    Yes. Still not exactly the same build as what I have. I suppose it's possible that no 2 machine were exactly alike and they could have the double back gear on one but not another as a bolt on option that could be added or removed.
    Thanks for the help.
    Shawn
  20. #18
    Sep 2016
    Missouri
    781
    668
    221
    VintageMachinery.org | Welcome
    I'm working on a phone.
    Here is a picture of the 14 inch 4 step . Hope the picture works. My phone doesn't allow preview or edit.
  21. #19
    Sep 2016
    Missouri
    781
    668
    221
    I believe these lathes could have been ordered to customers needs and your lathe has had a lot of years that things could have been wrapped out.
    It looks like a good lathe. Install a motor and proceed with care. The publication reprints show spindle speeds. You should be able to figure motor rpm's and pully size from those spec's
    Good luck and enjoy your lathe.
  22. #20
    Oct 2014
    Utah
    76
    13
    8
    Thanks. And I will do. When I picked it up I had good intentions. And then it got pushed back for more important things. Now I have come into some simple jobs I can make some money on so it it's more of a priority.
    I will post pictures when it's up and running and all cleaned up.
    Thanks again
