CatMan
Hot Rolled
- Apr 12, 2005
- Brandon, MS
I'd like a recommendation from all you gents & gals about reaming some cast iron holes. Parameters as follows:
Material: gray cast iron
Machine: #40 taper VMC
Holder: ER32 Collet, presume machine will probe to locate hole
Coolant: None, air blast only
Hole: Through hole, about 1.75" long. 11/16" diameter
Volumes: high. This is a long term job. Will be about 150 - 250 of each size weekly.
Tolerance: +/- 0.0004" on dia.
Hole will need to be sized 0.0005", 0.005", or 0.015" bigger.
Lack of coolant seems to be a big issue. I've always heard cast iron should be machined dry, but I really want to do it dry for a housekeeping perspective. Parts get wet, the cast iron chips & dust will stick to the wet part. Dripping coolant out in the floor causes a slick spot, etc.
I've started out with the generic 6 flute carbide tipped running about 400 RPM feeding at about 10 IPM. I'm slowly fading these out and replacing with full length carbide flutes. The steel flutes on top of the carbide of the current reamers seem to be what's wearing the most.
Obviously faster would be fantastic, but the real issue is hole size. I'd like to have a nice predictable tool life so I can be preventative about tool replacement.
So please. Let's hear your experiences. I'd like a recommendation on brand/type and also a feed/speed suggestion.
