cast iron or steel - gears on an old lathe - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21
    Mar 2003
    Vermont
    497
    122
    132
    Quote Originally Posted by DMF_TomB View Post
    malleable iron is heat treated cast iron. Chinese had it easily 2000 years ago.
    That's news to me. Ever hear of magnesium?
  2. #22
    Aug 2019
    8
    6
    Thank you for the information! I did contact Grizzly and was told that they did not have any parts for it, but I'll add your information to the file. Yes, the "banjo" piece is not missing, just needed to take it off to get the gears off - they were warmed and pressed out. Based on your, dgfoster, and others recommendations, I am strongly leaning towards ductile iron casting.
  3. #23
    Aug 2019
    8
    6
    Probably a dumb question but.... why? Maybe this is where the choices of shaving, shaping, hobbing or grinding come in?
  4. #24
    Apr 2018
    3,795
    1712
    Quote Originally Posted by b.rett View Post
    Space cutter and a dividing head is good enough for these, actually.
  5. Likes b.rett liked this post
  6. #25
    May 2006
    Seattle
    1,969
    38
    377
    Fix it.
    Here's how I did
    metalmagpie
  7. #26
    Mar 2011
    Geneva Illinois USA
    6,343
    2747
    2468
    belt buckles, , pipe fittings, C clamps and many many other items were made from malleable iron long before ductile iron was invented discovered. even regular grey cast iron comes in different grades. the stronger it is the harder to machine.
    lathe gears hard to say what made out off. i have seen zamak or zinc aluminum alloys too. even seen plastic gears on really cheap stuff. of course a high strength heat treated steel is sometimes used for gears too
    Yes, but a special cast iron called white iron.
    Tom
  8. #27
    Aug 2011
    Oregon
    2,557
    587
    780
    My chinese lathe, a Victor (But made in the PRC!) had fixed compound change gears made with two slightly different foreign tooth forms*, I'd never even heard of such a thing (Still don't know why they did that) and ran one against the other because, yes, they were that close to the same.
    I machined off the teeth, made a brass ring which I pressed on and fixed to the hub with setscrews running between the brass/steel press line like keys, four of them, then sent the gear to my favorite gear cutter with another gear with the correct tooth form and they cut it. That was at least 15 years ago and it still shows no wear, looks funny, guess I could blacken the brass,,,,
    *Probably module? they looked almost identical and appeared to run together, which they did for about 10 minutes!
  9. #28
    Jan 2014
    Utah
    600
    1497
    257
    Quote Originally Posted by johnoder View Post
    And to follow on Jims'
    ph
    What am I looking at here?
  10. #29
    Jan 2014
    Utah
    600
    1497
    257
    Quote Originally Posted by 10 fingers View Post
    We manufacture thousands of new change gears annually. Both as specials and sets for machines we build. For typical applications gray iron bar is ideal. If using steel, gears must have lubrication.
    How amazingly appropriate that your "metal type" is Cast Iron! This will soon be ruined when you reach 500 posts. Too bad!
