Luke Rickert
Hot Rolled
- Oct 24, 2007
- OSLO
I have searching online for information about the process of applying vitreous enamel to cast iron parts. I can find information on jewelry but nothing on what is really a very common industrial process (or at least a historically common process) Maybe I am using the wrong terms but hopefully someone here has some ideas.
My only even remotely related experience is with ceramics in school many years ago. Without having the necessary equipment on hand I can't experiment but given glazes for ceramics are relatively simple, can you apply enamel coatings to cast iron with the same sorts of basic equipment (water suspended glaze and a kiln etc)? It seems likely it is more difficult with iron as getting the coating to stick might be hard as partially fired ceramics are rather more open grain than cast iron and oil etc is going to be much more of a problem with iron. I would guess you also need to use solvent based glaze as the water based might cause rust. I imagine the temperatures are going to be lower as I think the iron would melt with high fire glaze temperatures.
Maybe I should just be looking at powder coatings but they are plastic and there is something nice about real enamel.
thanks
Luke
thanks
Luke
