tuprox
- Jun 16, 2014
- New Jersey
I need to make a number of pulleys of specific sizes that I can't easily find for reasonable prices but I have a forge and materials to cast them then turn the on a lathe. I'm looking at using a 2-5HP motor for various applications.
ZA27 is something like 72.5% zinc, 27% Al and .5% copper and it is very close in properties as cast iron. It's very hard and seems fairly resistant to surface corrosion. I don't have a ton of zinc, but I can probably find a source for it.
On the other hand I have access to 100-1000's of lbs of extruded aluminum (high quality heat sinks) and maybe some very heavy duty window frames & possible some pistons, cylinder heads and other automotive parts. I can keep all these types seperated so the alloys don't get mixed. I also have lots of access to 6061 T6 and some 7075 T6 though that is more stock but there is lots of scrap and lots of shavings (CNC) & cuttings of these - buckets, which I can melt down.
Now the ZA27 is almost 3x as dense so if I'm working with 12" diameter pulley's I woudl think that might help add inirtia to the equation for making a multi speed band saw & table saw & router (edger).
I'd cast the rough shape with the metal of choice and finish with it on the lathe and balance it using a balanced shaft and magnetic points to suspend/levitate the pulley to completely balance it - IDK if this is necessry or too much, but I'd like to get the experience and this seems a good project to learn on where I can't screw up too bad.
So can someone suggest a good metal? I guess I could also go to copper/Aluminum or some other as I have 100's of lbs of 99+% copper.
