Change gears for a Clausing 4902?
Likes Likes:  0
Results 1 to 2 of 2
    May 2010
    Cambridge, MA
    1,648
    71
    942
    Default Change gears for a Clausing 4902?
    I want to wind a 3/8" coil which is 8 threads per 3 inches or 2-2/3 TPI. My blacksmith has a Clausing 4902 which, like most lathes in that class, only goes down to 4 TPI. Is it possible to use change gears to run the carriage at 2-2/3 TPI?
    Aug 2014
    bainbridge island
    1,170
    234
    275
    need a 1:1.5 ratio between spindle and leadscrew. probably not hard to figure out.
    or a 3:1 ratio if the leadscrew is 8 tpi. or some other ratio if you have a quick change gear box.
    3/8" wire is likely stout enough to push the carriage along with the coil, no need for gearing provided the bushing(s) is close to the mandrel you're coiling the wire on. run the lathe backwards so the torque needed to coil the wire is lifting the carriage off the lathe and i suspect it will push the carriage forwards without deciding to coil over itself.
