Martin P
Titanium
- Aug 12, 2004
I wanted to replace some corroded looking fuses in my 1987 Ford 655 backhoe, and since I could use spare fuses anyway I ordered a boxed assortment of 200 fuses from Ebay ("torpedo" style ). I swapped them in and did think they looked a bit misshapen, since they were not as pointy as they normally are.
Later I was working with the headlights, the worklights and the heater fan on, when 2 of them failed.
I noticed that the fuses looked fine, as in the metal strips were not melted, but closer inspection showed that the fuse body itself was melted on 2 fuses!
Turns out the fuse body is not ceramic as advertised, but plastic. When resistance created heat, the fuse body got soft and the spring holding the fuse in place compressed the fuse until there was no longer enough contact.
I do not normally bash chinesium and try not to generalize, but this right here is garbage. Nothing ceramic about it.
It must be my fault to expect such a simple part to be non-screw-up-able. I was wrong.
I remember a Youtube video of fake chinese household resettable fuses. They were not a fuse at all, only made to look like one.
So this just as another warning to all to not expect the normal.
Note melted looking ends:
