I'm repairing a shaft and drive hub ( 1in. dia. steel ) that had a 1/4in
hi profile woodruff key holding the shaft to the hub along with 2 setscrews.
The shaft is the main rotor of a wood chipper so it's subject to plenty of
shock loads. The hub is almost 1.5 in long and after broaching can take
square key stock the full length. I can either cut a full length slot in the
shaft or redo it like the manufacture did.
Was it done with a woodruff key just for quicker production or am I
missing something?
I'm leaning to the longer square keystock unless somebody has a
good reason to do it the original way.
David
missing something?
David
