maicomutt
- Jan 13, 2019
- Mansfield,Ohio
Hello all, am searching for my first lathe. Was originally looking for a South Bend simply because they seem to be more abundant.I'm more interested in what the machine can do for me than a name tag so I'am open to all suggestions.Will be for home shop use. I maintain and modify older Harleys and vintage dirt bikes for personal use so parts for those along with tooling would be it's primary usage.
I currently do all my "fabrication" with a Chinese drill press,a 4" angle grinder and a butt load of hand files I've done surprisingly well at that for many years but the limitations are obvious. The lathe is a Cincinnati 13x42 Hydroshift which the seller nor myself knows much about except that it ran when moved.I believe it is a 220 3 phase motor which is one of my questions, am currently having new shop put up but only wanted to wire it for 110 and 220 single, is it doable to convert this machine to run off single phase? Is this even a machine a newbie should even consider starting out with? Whats a Hydroshift? Was also concerned about parts and tooling availability. Would I be able to thread bolts and such down to 1/4" dia. Seller says it comes with a "bunch" of tooling and is looking to get $1000 out of it and its just the next town over.
Here are some pics the seller provided. Any and all comments and your time are appreciated.
