I have an old bullet head clausing colchester lathe 13" I believe it is a student master Model 6525. One of the teeth on a 14/24 gear in the head is broken off. It was like this when I bought it. I have just stayed out of that gear when using the lathe. My question is: Are the gears made of hardened steel? I am thinking of welding up the gear tooth and machining it down. I just wanted to know what metal I am working with before I jump into this project. Any information or suggestions would be welcomed: IE: what welding process to use, Mig or Tig, what filler metal to use, ect. If I do this I want it to be correct. As I am sure all of you know that parts are hard to find and expensive.
