Happy NewYear folks,
I bought a used CC 8000 or Master 2500 13x40 a month ago and have a few issues that need to be resolved. I’m running the 220 3 phase motor with a VFD. The lathe has an electro-mechanical brake that is activated by a solenoid
With the lathe out of gear the headstock spindle is hard to turn. If I run the lathe for 10 minutes or so the metal gets warm in the area of the brake. I expect the brake is engaged when the brake solenoid is not active. With the VFD output going directly to the motor the other electrical parts of the lathe are not powered. With normal 3 phase power, one leg is used to power the other electrical components,one of which is the brake solenoid.
I think it is a easy task to remove the solenoid but I’m wondering if I need to open the headstock gearbox cover and remove the brake pads too?
Thanks guys R
Thanks guys R
