bruszw1
- May 26, 2012
- Windsor CA
Hello,
I recently took delivery of a used Clausing Series 22V drill press in pretty good condition for the price: no spindle sloppiness, no evil bearing noises, only one small hole in the table. It has a 110V 1ph motor, 1725 RPM. It has a new variable speed drive belt, and it's been sitting around for a while. It appears that it has never seen the outdoors.
Here's what happened when I fired it up yesterday for the first time:
- started slowly at the lower end of the speed range; I had to help the thing start spinning;
- it ran fine at the lowest speed (300 at the spindle);
- it ran OK thru the speed range until I got to about 700 (top speed is 2000), then a breaker clicked in the motor and it began to slow down;
- at a lower motor speed, the breaker clicks and the motor accelerates, then, click, slows down, etc.
- I could only get the thing to run in a stable fashion when I decreased the drive speed by about 100 RPM
- it does not run at all when connected to GFC outlets in the shop (I've heard this is common with older motors)
What's going on here?
Today, I'm opening up the motor and inspecting wiring. I'm also gonna connect direct to a wall outlet without GFC. It is currently connected to the wall with a big extension cord (600V). The motor came with a 600V 12Ga power cord.
Thanks for your responses!
Walter
Walter
